-   -   Interpreting Engine Numbers (http://forums.pelicanparts.com/porsche-911-technical-forum/252436-interpreting-engine-numbers.html)
Shawn 357 11-21-2005 01:31 PM
I have a motor I just pulled from an SC and I wanted to know how to decode the engine number.
The number I have is:
930.101.103.4R
I tried searching for this but couldn't find it. Any help is greatly appreciated.
javadog 11-21-2005 04:57 PM
That's not the engine number. You are looking for a stamped number, such as 930/03 or 930/04. That will be the engine type number, which identifies what market it was built for and what specifications it has. There is also a serial number, which is probably pretty irrelevant for your quest. Look on the right side of the fan housing to find the numbers.
JR
Shawn 357 11-21-2005 06:28 PM
Thanks, I pulled this # off of it:
6402859
I hope this is the right one and I appreciate the help. Is there a link you can refer me to?
Wil Ferch 11-21-2005 07:29 PM
That's the serial number stamped vertically on the right side of the fan housing...look a bit further to the right...but on the horizontal FLAT of the engine..... 930/21, etc kinda number....
Wil
EDIT: See here ---> http://forums.pelicanparts.com/porsche-911-technical-forum/251933-engine-serial-number.html
