Distributor Wiring question
Inside the large green wire is a smaller green wire and a copper stranded wrap. Does anyone know which one is the (MAG +)?
Easy to verify check with ohms meter but I believe its the inside wire is plus but verify that there is no continuity between that wire and ground
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
The shield [braid of the coax] is ground at terminal #31d of the CDI unit, and the inner conductor is the signal lead at terminal #7 of the CDI unit.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
