-   -   Check Engine Light Install, Early '89 (http://forums.pelicanparts.com/porsche-911-technical-forum/252518-check-engine-light-install-early-89-a.html)
drums 11-21-2005 08:05 PM
After putting in a '97 V-Ram, to pass Ca. smog, I need to install a check engine light on the dash [connected to the alternator wire]
so it will turn on with the ignition and off with the alternator light. How is this proceedure done?
Thanks,
Drums:confused:
