| KobaltBlau |
11-23-2005 01:37 PM |
Originally posted by cnielsen
I spoke with John at Engine Builders Supply yesterday and I think I am going to go with the most bang for the buck option and not get too crazy here. He recommended going with a 9.5:1 JE piston so we don't have to modify the Mahle cylinders. Add GE60 cams and then save weight with a lightweight clutch and valve springs.
This should be a good choice, but you will want weber 46s. I would do the ARP rod bolts too if you are doing GE60 cams, because with those I think you will want to run it to 7000 at least, not sure the stock 3.2 rod bolts will love that. I think a Mod-S or GE40 would bring the powerband down a little.
