Yeah, first engine drop, and my new jack
Yes, the first engine drop is just finished, and I did it alone. Well, I needed help from the wife to balance the engine on the way down. Every thing went smooth, thanks to my new AC floor Jack, the high lifter. Thanks to Wayne for his detailed descriptions in the 101 book, and thanks to everyone on this forum for many nice and informing engine drop threads.
I made a cart that i placed between the jack and the engine. This way the engine was already on the cart when I lowered it to the ground. Had some balance problems, because I wasn't paying attention when I positioned the jack. Here are the mandatory engine room pics. ![]() A few questions if I may: The rear right engine mount was broken (maybe this is the cause of my shifting problems), but the surface of the fracture looks "new" with no rust. Is it possibe that it snaped when I tried to undo the mount bolt? I had to use considerable force using o 1,5 foot arm. What do you think? Is it possible to drive with only one rear mount without noticeing? Can I weld this, or should it be replaced? Also, there was an unattached electrical connector right behind the fuel distributor. Any idea what this is?
Arnljot 1980 930 GT35R, TurboKraft IC, 965 P&C, 964 Cams, Tial WG, ported heads, BLWUR, RarlyL8 hdrs&mfflr, Zeitronix logger & wideband 1989 928GT 1972 BMW 3.0S |
Well done. You will enjoy having that jack, wish I had one. As for the rear engine support, I am sure it could be welded but you might be better off looking for a salvage part in one piece.
Walt 82SC 3.0 81SC 3.6 |
Check out rennline design, they have a really nice looking replacement part that is not too ridiculously priced.
Brian Starr Alabama Region PCA 1983 911SC/Rebodied as 993 w 3.6 1995 911 C2 (Sold) |
Re: Yeah, first engine drop, and my new jack
Senior Member
One reason why the engine mount may be still shiny, is that the two pieces were still rubbing together everytime the engine moves.
Very nice jack, that may be on my Christmas wish list! Joe A
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Keith: Yes, I used i High torque impact wrench trying to undo the bolt. The bolt wouldn't move, but i got it moving by using al long arm on my 20mm socket. I think it snapped then.
Joe: Tha AC floor jack is fabulus. I wasn't even able to utilize its high lifting capability since my 930 front lip touched the ground. One surprise though; its very heavy compared to my other jacks. Close to 80 lbs!!
Replace that rear mount bar. Give PartsHeaven a call. I only twisted mine a little, but I replaced it.
steve old rocket inguneer |
$125 and it looks cool....
Yeah, that rennline SS bar looks really nice.... with WEWO mounts I can use it in the living room, thats how cool it will look
Thanks for valuable input guys.
I was too tired last night, after the engine drop, to write about the background for the engine drop, so here comes: I haven't really been using the 930 for the last two years. Just some shorter road trips and no track driving (DE) at all. Third gear was pretty bad last time I whent track driving, grinding badly if I didn't pause the shifting for about a second. So I figured it was no point until I fixed it. SInce I started my own business abount two years ago, there have been no time for driving and no time for fixing and improving the 930. Now, however, the business is up and running good, and since I'm tired of working every night and every weekend, what better way to spend my "new" free time on than fixing the turbo? Anyway, tha plans are as follows: - Fix 2nd and 3rd gear synchros + + - New sport clutch - Stage 1 and 2 suspension upgrades described here based on Elephant Racing parts - New engine mounts crossbar and mounts (Wewo) (I don't know what to to with the transmission mount yet, as crossbar and mounts are one piece) - New plugs + wires + coil + dist. cap - General tidying of the engine and engine room
