MM 12-Plug Dizzy without rotor... Worth anything?
I got 2 engines recently as cores. One is a 3.0SC block and the other is a 2.7 RS spec one. I got as a lot, a pair of RSR cams with the part no. cast on and a MM 12 plug dizzy. Came with points and cap but no rotor.
What's the going rate these days? I'm keen to raise some cash to fund EFI! Sprint. |
Sent you a pm.
1500-3000 is the range on the distributor.
cams, not sure but bet the guys at TRE motorsports know. |
| All times are GMT -8. The time now is 06:09 PM. |
