A "tip" on sparkplugs
You would have though I learned my lesson in May. A refresher for those that missed it:
http://forums.pelicanparts.com/porsche-911-technical-forum/223679-odd-spark-plug-question.html?highlight=plug After discussing it with another fellow, this is a common problem - the vibrations shake the tips of the plugs off. Attempting to diagnose another problem today I found that it happened again. The tip came off and fortunately this time was trapped in the end of the spark plug wire. I was able to get it out with little effort. So the "tip" on tips is to ensure those things are on there gorilla tight. You cannot retreive them with a magnet if the fall off. |
Wow, isn't anything easy?
| All times are GMT -8. The time now is 07:17 PM. |
