jevvy's Avatar
UK Mobil1 gearbox oil supplier
I want to change the oil in my G50 gearbox and I have read on here that 'Mobil1 75/90 gearbox oil' is the stuff to use however I cant seem to find it anywhere in the UK.
Has anyone found any in the UK and if so please can you tell me where...
Thanks in advance
'89 3.2/3.6 coupe
Old 02-14-2005, 03:36 AM
If no one has an answer you should try calling or Emailing them directly:
http://www2.exxonmobil.com/Siteflow/Country/SF_CY_UnitedKingdom.asp
Warren & Ron, may you rest in Peace.
Old 02-14-2005, 05:16 AM
Mobil helped me source it - I think I contacted them via e-mail.
I was pointde to Cotswold Chemicals, 01453 825292, based in Stonehouse, Glos.
"Racing is Life. Anything that happens before, or after, is just waiting"
1988 Carrera 3.2 Sport Coupe - my mistress
2012 BMW F11 touring - the dog bus!
2017 VW T6 Transporter - the holiday bus/workhorse
Old 02-14-2005, 05:40 AM
jevvy's Avatar
Thanks for your reply guys
I have called Cotsworld Chemicals and they have it is stock
1 Litre is £8.50 + VAT
20 liters is £128 + VAT
According to the book the G50 gearbox needs 3.4 litres.
If I buy 4 x 1 litre it will cost £34+VAT+£8 postage
If a few locals with G50's need to do a gearbox oil change soon then we can get 5 changes out of a 20 litre tub with a few liters spare and it will only be £25.50+VAT+postage each
Its a shot in the dark....any takers????
'89 3.2/3.6 coupe
Old 02-14-2005, 07:01 AM
jevvy's Avatar
Hi Guys
I'm in the process of doing my 3.2 - 3.6 conversion and will be changing the gearbox oil before I put it all back in. I have fully drained the oil that was in there so it is totally empty.
I just wanted to double check how much oil I need - I have read that the G50 needs:
3.0 or 3.1 or 3.4 liters
Basically do I need 3 or 4 liters?
'89 3.2/3.6 coupe
Old 11-23-2005, 03:41 AM
jevvy's Avatar
too late guys - I decided to stop being a tight-git and just ordered the 4 liters
thanks anyway
'89 3.2/3.6 coupe
Old 11-23-2005, 06:04 AM
Jbabic's Avatar
I have read however, that in cold weather the mobile 1 may be a little too thick for smooth shifts. Just an FYI.
Old 11-23-2005, 10:09 AM
