Lynn-75's Avatar
Cabriolet panel replacement?
Hi,
The plastic window cracked when I was raising the roof. Is it possible, and if so, where can I get, a rear window or rear section replacement?
I hate the thought of replacing the entire top which is in very good shape.
Thanks,
Lynn
“If you don’t know where you’re going,
you’ll end up somewhere else.”
—Yogi Berra
Old 11-27-2005, 09:42 AM
What's Facebook?
turborat's Avatar
Lynn, A good upholstery shop should be able to replace the window panel without replacing the entire top.
Turborat
"’Cause every once in while, the lion has to show the jackals who he is”
1979 911 SC - 2100 LB track rat
1986.5 928 5-Speed - 36,000 miles
2001 330Ci
Old 11-27-2005, 10:19 AM
