-   -   SC, Carrera Bischoff Muffler Modification, Mod, Gut, Gutting, Dual, Two Out (http://forums.pelicanparts.com/porsche-911-technical-forum/253295-sc-carrera-bischoff-muffler-modification-mod-gut-gutting-dual-two-out.html)
75Carrera 02-21-2006 07:26 AM
I added a restrictor plate option by welding in a flange where the plate can be added when I want to quite it down for long trips with a passenger... But why? It sounds so sweet!
http://forums.pelicanparts.com/uploa...1140535276.jpg http://forums.pelicanparts.com/uploa...1140535444.jpg http://forums.pelicanparts.com/uploa...1140535553.jpg
M Scahfer 08-15-2006 04:16 PM
Gordo, got my muffler opened up and did a modified gut, just took out the pipes to the right of the middle baffle(in the picture that would be on the left of the baffle). I did some sound/video of the stock Bischoff 5/87 muffler at idle, 2000 rpm and 4000 rpm before the surgery and will do the same rpm's when the muffler is done at the welder's and re-installed.
http://forums.pelicanparts.com/uploa...1155682459.jpg
M Scahfer 08-15-2006 04:31 PM
from the top: outlet pipe, crossover pipe, and inlet pipe.
The stock muffler weighed 20 lbs. and the pipes and third/right baffle I cut out weighed 44oz. or 2 3/4lb.
http://forums.pelicanparts.com/uploa...1155684652.jpg
Eric-325I 08-16-2006 08:03 AM
What is the weight difference between the Bischoff (as on my '79 SC) and the average M&K?
As I don't have to deal with emissions and my original cat was most likely long ago clogged, I replaced the cat with a 'test' pipe last weekend. I can't get over how much louder the Bischoff is and sounds muuuch better as well. I can't imagine it much louder as I'm already afraid to wake up the neighborhood at night.
Eric
911pcars 08-16-2006 11:23 AM
While we're on the subject, anyone have a chance or a reason to dissect a Dansk 2in/1out or 2in/2out? Better yet, someone with photos?
Inquisitive mind wants to know.
Sherwood
JMatta 10-11-2007 06:34 PM
Yes...I have a Dansk 2 in 2 out that I'd love to know what's inside. My car is already quite loud, as I'm running headers on it (2.4 ltr).
david dolan 10-22-2007 12:10 AM
Another explanation
The mechanic I had when I lived in San Diego wrote the following technical article about making a dual outlet muffler. It's an interesting read.
http://www.dietersmotorsports.com/twinpipe911.htm
:cool:
stownsen914 09-02-2009 07:23 AM
Quiet Boom, Tim, or Gordo:
I'm planning a sport muffler mod soon on a stainless 911 muffler. Which alloy wire should I use with a MIG for welding? Thanks.
Scott
stownsen914 09-06-2009 09:14 AM
Scott
Anyone know? Thanks in advance.
Scott
MrPerkles 09-06-2009 01:17 PM
http://forums.pelicanparts.com/uploa...1252268206.jpg
berettafan 09-06-2009 02:35 PM
it would seem part of the purpose of the various routings inside these mufflers is to equalize backpressure for both sides. yes? no?
911pcars 09-06-2009 04:22 PM
What does the inside of a 2in/2out Dansk look like? Anyone?
Sherwood
Gordo2 09-06-2009 06:40 PM
Replies
For M Scahfer: nice work, are you adding a second tailpipe as well or just gutting to get a litte more sound? Either way, for the cost of a used muffler, it's fun to play with. I probably went a little overboard in how I went about mine.
Scott: I went with whatever Lincoln wire they have at Home Depot/Lowe's - I think I went with a small diameter wire - like .025 or something.
Gordo
stownsen914 09-07-2009 08:13 AM
Also less back pressure in general (for both sides).
Gordo: thanks for the information.
Scott
911 tweaks 06-20-2012 07:02 AM
any updates form those who did any mods to a muffler as to how their version worked out...??
thx, bob
M Scahfer 07-01-2012 02:04 AM
Muffler gut on '88 3.2
It's been almost six years since I sawed into my muffler after gordo's post that showed me best what and where to cut. Sounds great and with the by-pass pipe engine breaths better. The guy who welded it up said it was tricky, two thin layers of the shell make it harder. Plus the weight savings is nice. My version is a one in and one out muffler still.
