Aussie's Avatar
Grinding pedal
Hi all,
Was driving home today when I noticed a kind of grinding feeling coming through my accelerator pedal for about the 1st inch of travel.
It happens in each gear, only when I release the clutch.
Anyone got any ideas what it may be?
Simon
1969 911 T (SOLD), 1977 911SC (SOLD), 1999 BMW M3 (SOLD), Current Car 2005 Lotus Exige
Old 11-29-2005, 09:52 PM
Super Moderator
cstreit's Avatar
I'd check all the pivot bushings first...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 11-29-2005, 10:02 PM
DW SD's Avatar
I had the same problem. I bet the inner piece of the throttle linkage is hanging up on the arm which pulls on the clutch cable. The clutch arm is attached to the cable by a yoke.
If your throttle stop isn't set properly (not high enough) too much force in the throttle linkage can bend the inner piece so that it hangs up with the clutch linkage. Post a picture of the parts from PET and I'll tell you tell you which one. I know this description will be nearly impossible to follow.
1971 RSR - interpretation
Old 11-29-2005, 10:28 PM
