| Registered Join Date: Nov 2000 Location: kcmo
				carrera ???'S
			Do the plug wires have to have the big rubber insulation around it? What size is the deep socket to remove the cylinder temp sensor from the head? Also after trying to start the car I proformed a spark test with a odl GM spark plug and got a blue spark, But when I pulled a motor plug it is RED spark?If I get spark the fuel pump and DME relay will both be working? | ||
|  11-30-2005, 05:42 AM |
| Registered Join Date: Aug 2002 Location: Galivants Ferry, SC
			The big rubber boot seals the engine and running without it would cause a big cooling air leak..... - Wil
				__________________ Wil Ferch 85 Carrera ( gone, but not forgotten ) | ||
|  11-30-2005, 06:06 AM |
			I'm talking about where the wires snake back to the dist. They have fatter rubber on them as they go up over the ALT/FAN. I didn't notice on the drivers side as the car is not here.
|  11-30-2005, 06:26 AM |
| Registered Join Date: Apr 2005 Location: Co. Carlow, Ireland
			I seem to remember that the size of the cylinder head temp sensor as being 14mm. I just used a ring spanner to remove mine but hacksawed a gap out of it to fit over the wire.
				__________________ Charles '84 911 3.2 | ||
|  11-30-2005, 06:28 AM |
			I don't know why they have the fatter rubber on. Maybe its because as they go over the fan they are lying on metal as apposed to the plastic shroud, and so need the extra insulation. I just left the insulation on.
|  11-30-2005, 06:31 AM |
			Old temp sensor is 13mm...the new one most people buy to replace the old one with is.....ta dah ! .... 14 mm.... One of many "cute" things Porsche does to drive us CRAZY !!!!!!! Yep....may require you to slice ANOTHER deep socket !!!!! - Wil
|  11-30-2005, 07:37 AM |
