-   -   engine compartment sound pad template? (http://forums.pelicanparts.com/porsche-911-technical-forum/253866-engine-compartment-sound-pad-template.html)
rfuerst911sc 11-30-2005 02:49 AM
I am planning to remove my CIS injection system over Christmas and replace with EFI. When I do that I would like to replace the sound pad. The previous owner shoved in a piece of insulation board so I don't have the original pad. I would like to make my own pad by using some aluminum foiled rolled foam I have laying around but I wondered if anyone had a paper template that would get me close in regards to the shape and size? Thanks
Mike Bonkalski 11-30-2005 04:52 AM
Just tack up the bulk material with some double stick tape and cut to fit. Then remove and use some hi-temp contact cement for final installation. I can take some basic measurements from my pad to get you started.
I used the silver wrapped stuff for my replacement, but looking at it now I prefer the look of the standard black material - less jiffy-pop.
donstevens 11-30-2005 07:18 AM
[QUOTE]Originally posted by Mike Bonkalski
[/QUOTE
Mike,
I need to do mine too and will take your advice. Thanks for the helpful suggestion and the humor in the "less Jiffy Pop" quote.
Don
