-   -   EFI Conversions - Are they reliable for daily use? (http://forums.pelicanparts.com/porsche-911-technical-forum/254191-efi-conversions-they-reliable-daily-use.html)
RarlyL8 12-01-2005 06:18 PM
Many of you have done the various CIS to EFI conversions. I have not seen any remarks regarding long term reliability in a daily driver situation.
If you have done this conversion to a normally aspirated engine or a 930 would you trust it on a long trip? Would you trust it as a daily driver?
What components would be most likely to leave you stranded?
Which manufacturers of hardware or software are most durable?
mb911 12-01-2005 06:35 PM
mega squirt in my car would out dobt make it to CA and back
rfuerst911sc 12-01-2005 06:45 PM
The aftermarket EFI conversions aren't that much different than OEM units if you think about it. You have a ECU, a wire harness, various sensors, injectors, fuel rail and throttle body/bodies. If the quality of these components is good there is no reason the reliability should also be good. I recently ordered a complete
rfuerst911sc 12-01-2005 06:50 PM
I accidently hit the send button. What I was saying is that I recently ordered a complete EFI system from Motomotions, this kit included TWM throttle bodies,a Megasquirt ECU,Motomotions harness assy,their relay board,Bosch injectors and various brands of sensors. The quality of the installation is based on my ability as a shadetree mechanic but I don't doubt the quality of the individual components.
WydRyd 12-01-2005 08:18 PM
Agree, if installed and programmed correctly, there should be no reason why it'd be less reliable than an OEM setup.
911Mac 12-01-2005 10:00 PM
In a few more months my tbitz EFI conversion will be two years old. The car is a daily driver and has probably had over 30,000 miles put on it since the conversion.
I have had no problems. Car starts first time, everytime, and runs very well.
I would expect an EFI conversion, if it's done correctly, to be more reliable than a 20+ year old CIS system.
-Mac
beepbeep 12-02-2005 01:11 AM
EFI is digital. Cut a wire or disconnect a connector and it will stop working. Completly. That's both good and bad.
CIS can/will fail in a multitude of hard-to-troubleshoot ways.
David 12-02-2005 08:01 AM
That's only partially true. Many of the ECUs can run without some sensors hooked up. It's kind of limp home mode where they just make due with the info they have.
RarlyL8 12-02-2005 05:33 PM
Megasquirt is the product I was most concerned about due to it being possibly the least expensive unit out there.
What is the difference between the expensive $8000 units and the Haltechs and Megasquirts?
My car currently uses a minimized stock CIS system. It performs very well with component failures broadcasting their issues long before they quit. Even at that a system failure generally won't strand you - and that is most critical to me.
TOO RUF 12-02-2005 05:59 PM
I went with Haltech. It has a nice case to protect the ECU. It comes with the wiring harness and relays. It also comes with the Map sensor, temp sensor, air temp, TPS Sensor for about 1,100. It has the advantage of using low or high impedance injectors, and has ignition control built in. I found this to be a good buy.
bb 12-03-2005 05:59 PM
I've been using the Megasquit from TBITZ, on my 76' 2.7 Turbo. I haven't had a problem all summer and has given me such control of my fuel curve that it is awesome. It made the car feel like it has a whole lot more power and throttle response than before. I wouldn't go back
bb 12-03-2005 06:06 PM
Here's pic's. Rarly does the car look familiar? I saw pic's of yours a few years back and said I have to make mine look like that car.http://forums.pelicanparts.com/uploa...1133661912.jpg http://forums.pelicanparts.com/uploa...1133661988.jpg
RarlyL8 12-03-2005 08:42 PM
Yep, looks familiar. Seems we have similar taste in body styles!
Glad to hear these aftermarket systems are holding up. You never know about stuff like that, factory equipment is built to last a 100,000 miles. Aftermarket stuff is built to last until you get it paid for.
http://forums.pelicanparts.com/uploa...1133671332.jpg
niner11 12-07-2005 08:31 AM
Check out Megasquirt-II http://www.diyautotune.com/catalog/megasquirtii-engine-management-system-wpcb3-unassembled-p-59.html
I'm building the board right now and there is a ton of support if you have any problems.
Chuck
bb 12-07-2005 09:23 AM
The Megasquirt forum is very good. Between Tony and the board I have been able to tune my car, yet I knew nothing on how to do it when I installed it.
OScar
makaio 12-07-2005 09:42 AM
Rarly your car looks great as usuall and BB nice looking ride!
niner11 12-07-2005 06:29 PM
Just finished my MS-II tonight.
http://forums.pelicanparts.com/uploa...1134008504.jpg
http://forums.pelicanparts.com/uploa...1134008890.jpg
Now all that I have to do is wire it up................
RarlyL8 12-07-2005 07:20 PM
What are you doing? Building this thing from scratch? Man I thought I was anal!
mppickett 12-07-2005 07:26 PM
Nice work, Chuck. I'm down in Durham and have a MSII, also. Let's talk as we start wiring these things up (probably 4-6 weeks away for me).
Mike
niner11 12-07-2005 08:47 PM
I've learned a lot building this thing but you can get them from several venders completely assembled and tested for another 160.00. (250 + 160 $410.00)
BTW this setup is for a turbo charged Datsun 260 but the 911 is next.
Mike, let me know when you are setting up your car or if you need help building the ms. I'm pretty close by.
Chuck
RarlyL8 12-08-2005 10:39 AM
Thanks. Just gathering info for now. We have "other" issues to settle at the moment. ;)
ruf-porsche 12-08-2005 12:44 PM
ARe we talking Canada or California?
Wisconsin is pretty close to Canada compare to California.
anthony 12-08-2005 03:37 PM
Has anyone done before and after dyno tests on a CIS to Megasquirt upgrade? Specifically I'm curious if an SC would gain power. I know that tbitz had some dyno charts on his web site but they were with SSIs and other upgrades thrown in.
makaio 12-08-2005 03:43 PM
Anthony, I believe Noah did a before and after run with his after installing Tony's kit. If I'm not mistaken it was 10-15 more horses at the wheels.
