Metal Guru
Guys,
I decided to replace my oil return tubes today. I started with what looked like it would be the hardest one to replace: the front left hand side tube. Well, I have all the recommended aids; Dow 111 lube, hose clamp and circlip tool. The problem is I can't get this tube into position. When totally collasped it's too long to start in the holes. Tried installing by sticking the large diameter end in the crankcase firts, still no joy. What am I doing wrong? Thanks in advance.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
I'd love to help but I'm not really clear on what the problem is.
Can you be more specific or take some pics? |
the left front one won't go in until the left rear one is out of the way. the gold sheetmetal tubes are the ones to use. aluminum tubes harder.
Senior Member
Wayne's customers get the best technical assistance available.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Metal Guru
Update
Finished it off last night. What an adventure. When I did a search on this someone said the install process was a puzzle. I wholeheartedly concur.
Thanks John Walker; great advice as always.
