Lexluther's Avatar
Send a message via ICQ to Lexluther
Oil pressure on 911e
Just a quick question, how much oil pressure should a 2.2 litre hold? At idle, at 2500 rpm?... Thanks
1987 Porsche 944
1971 Porsche 911E..(It went home,Germany!)
1969 Porsche 912
1964 Porsche 356c..(roller)
1988 Porsche 924S (PARTS CAR)
Old 12-02-2005, 06:25 PM
Type911's Avatar
My 2.2 holds about 1-1.5 bar per 1000 rpms.
2021 Spyder
2019 Carrera T
2007 911 GT3
1973 911E
RGruppe #295
Old 12-02-2005, 06:36 PM
Lexluther's Avatar
What is that in psi?.. My gauge is in increments of 20's..IE 20, 40, .....
I am just curious what the oiling specs are.
1987 Porsche 944
1969 Porsche 912
Old 12-02-2005, 06:39 PM
GrantG's Avatar
1 Bar = 14.5psi
2022 GT3 Manual, 73 Carrera RS 2.9 Twin-Plug MFI Carbon Fiber Replica
Former: 18 GT3 Manual,16 Cayman GT4, 73 911S, Two 951S's, 996 C2, 993 C2, BMW 635CSi Euro, Ferrari 550 Maranello, 06 Evo IX w/ many mods
Old 12-02-2005, 07:56 PM
Lexluther's Avatar
So basically at 1000rpm=20psi(approx.) 2000=40psi..this is pretty much average....
1987 Porsche 944
1969 Porsche 912
Old 12-02-2005, 08:03 PM
Jeff Alton's Avatar
Always check oil pressure with the engine at operating temp. Anywhere between 10-15psi per 1000 rpm is good.
Cheers
www.turn3autosport.com
Old 12-02-2005, 08:16 PM
Lexluther's Avatar
We started my car today, first time since my friend took my injector ppump apart and "cleaned" the petrified gas out. ANyway, the pump still isnt 100%, but it did run under its own power, and I noted the oil pressure.... and even idleing kinda rough, and around 1000 rpm...the oil pressure was about 20psi...as we rev'd it up to 2000-2500 rpm, the oil toped as high as 60psi....warm.
1987 Porsche 944
1969 Porsche 912
Old 12-02-2005, 08:33 PM
Type911's Avatar
Congrats on getting it running.
Your oil pressure is fine. Is it running well enough to
drive the car ?
2021 Spyder
2019 Carrera T
2007 911 GT3
1973 911E
RGruppe #295
Old 12-02-2005, 08:39 PM
Lexluther's Avatar
I made a loop around my yard....is not running very well...the underside pump is leaking and I dont think its pushing the appropriate pressure..I am trying to get in touch with another user who has one but nothing so far.
We also think the injector pump is out of time, we got in a hurry installing is an we will recheck tommorrow... It is also running pretty rich and smoking white.
1987 Porsche 944
1969 Porsche 912
Old 12-02-2005, 08:49 PM
Bandwidth AbUser
Jim Richards's Avatar
I'd strongly recommend you get the fuel pump leak fixed before running the car. Hopefully that's already your plan.
Jim R.
Old 12-02-2005, 08:54 PM
Lexluther's Avatar
yes...we used this one to troubleshoot the car, IE injector pump, as this was the origional problem... As soon as I can get the delivery pump we will start tuning the car. At least I now know the engine is good, and the clutch works.
1987 Porsche 944
1969 Porsche 912
Old 12-02-2005, 09:00 PM
Bandwidth AbUser
Cool. Best wishes on getting your 911E sorted out quickly. And post pics of it, too!
Jim R.
Old 12-02-2005, 09:05 PM
Lexluther's Avatar
How do you add a pic?
1987 Porsche 944
1969 Porsche 912
Old 12-02-2005, 09:11 PM
Lexluther's Avatar
I think i figured it out, but my pics are all too big. they average 1.6mb each...
1987 Porsche 944
1969 Porsche 912
Old 12-02-2005, 09:18 PM
