defcon65's Avatar
bad AM radio reception
Just installed an Alpine CD/radio unit in my 85 Carrera - AM reception is really, really bad. It's got one of those wire-in-the-windshield antennas. Any suggestions on how to improve reception? I don't think I could bring myself to drill a hole anywhere to install a regular antenna. Maybe I will get that Sirius radio after all.
Thanks, Joe
Old 12-01-2005, 01:28 PM
Kirk911SC's Avatar
Isn't there a "adjustment" screw on the unit to fine tune AM during the installation?
I seem to remember one on my Pioneer when I installed it.
Kirk
- '00 Dodge Viper GTS - Steel Grey - Yep...a domestic.
- '87 930 - Guards Red - Sold
- '82 911SC - Grand Prix White - Gone
- '78 928 - Silver - Long gone
- '04 Subaru WRX wagon - Sold
Old 12-01-2005, 01:33 PM
defcon65's Avatar
Kirk, when I said 'installed', I meant I had it done at Best Buy. I'll look at my manual and see if there is an adjustment screw like you describe. I got lucky and found the senior technician who had actually done installs on several 911s before and he was able to do a professional job in a couple hours. Deck doesn't wobble in the dash, either. 20 year old Blaupunkt speakers will have to go, though - a little worn out to say the least!
Joe
Old 12-01-2005, 01:45 PM
Kirk911SC's Avatar
My speakers were toast too........could poke my fingers through them!!
Kirk
Old 12-01-2005, 01:47 PM
Counterclockwise?
The Bentley claims there is a booster in the car somewhere.
Anyone know where?
Rod
1986 Carrera
2001 996TT
Old 12-01-2005, 01:52 PM
Mothy's Avatar
Send a message via AIM to Mothy
Don't know about how your in glass antenna is configured (front or rear glass), but I have had problems in the past where the antenna was painted on the rear window glass (much like a demister) and had window tint film fitted. The tint film was conductive and was shorting the antenna (and the demister).
AM only effected - used to whistle and whine.
Tim
Swapped my WRX Sti MY02 for a Porsche 911SC '83
Keep buying parts to make it look older.
Mid life crisis is now in its 12th year.
Old 12-01-2005, 02:58 PM
defcon65's Avatar
Tim, this looks like it's embedded in the front window glass. GM had the same crappy solution with similar results on my '79 Olds Gutless - RIP at 57K miles. Maybe I'll just keep my Grundig Yacht Boy on the dash for sports and talk radio.
Joe
Old 12-01-2005, 03:06 PM
Joe,
Somewhere between the windshield antenna and the coax cable that plugs into the rear of your radio, there's some sort of an amplifier that came with Carreras that had that antenna setup. I have an SC so I can't say for sure where it's located......but I have seen it described on a search. Another alternative is a hidden antenna. The hot-rod guys always put these in their Ford coupes so there's no antenna showing. Check out what's available at a hot-rod shop.....I've also seen this online as I was one time considering patching my fenderhole and going with one of these. I ended up with a boosted power antenna and it solved the issue.
'82 911 SC
Old 12-01-2005, 03:22 PM
Get XM. Nothing on AM anymore anyway.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not.
2012 BMW 528i (wife's)
2007 Toyota FJ (rain and off road days)
Old 12-01-2005, 03:38 PM
one of gods prototypes
bell's Avatar
on the actual antenne behind the radio there is a thin black wire that splits off of it, that needs to be energized for the stock antenne booster to work (needs hooked up to the blue wire on the alpine harness)
however, if you have good fm then you may need to beef up the ground on the radio and possibly the antenne cable ground shield as am uses the cars chassis for it's "antenne". it's sometimes very difficult to get good am when dealing with aftermarket radios.
Brought to you by Carl's Jr.
Old 12-01-2005, 04:04 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
All AM radios need to be "tuned" at the antennae.
FM is OK without tuning.
The difference could be great between tuned and not tuned....as much as not getting the closest station or receiving so many that you need to tune a bunch out.
Bob
Bob Hutson
Old 12-01-2005, 05:02 PM
ruf-porsche's Avatar
Re: bad AM radio reception
Thanks, Joe
There a button that said am / fm on the radio. Push the button until you get a fm station. Viola improve reception. Don't need to buy a sirrius radio.
Old 12-01-2005, 08:14 PM
kqw kqw is offline
What Bell said; re: the black wire needing to be connected. However "News Flash" AM reception will probably be less than stellar unless you are very close to the transmitters or the AM station transmits a very strong signal.
The Fox
Carrera
Old 12-01-2005, 08:21 PM
defcon65's Avatar
Thanks for the info, guys! I'll look for that wire and see if it was hooked up. A buddy who is a shortwave guy mentioned the ground wire issue as well. As far as the power of AM signals in my area, the only one I really care or need to receive is AM 600 WMT, voice of the Iowa Hawkeyes and 100,000 watts from a tower 65 miles away. Comes in just great on the crystal set I built in the Cub Scouts back in '74!
Joe
85 Carrera
64 Honda Dream - for sale
71 Hodaka Super Rat - keeper
Old 12-02-2005, 11:42 AM
Flyer88's Avatar
Ditto on the black wire - it's about a 5 minute fix. Took me a year to figure it out.
Bill
87 911 Targa
06 Toyota Sequoia
Old 12-02-2005, 12:16 PM
Counterclockwise?
This is the black wire that runs with the antenna wire?
What did you attach it to?
One of my manuals suggest it should be attached to a booster.
Rod
1986 Carrera
2001 996TT
Old 12-02-2005, 12:23 PM
bell's Avatar
i never get to quote myself
the thin black wire needs to see 12v+ to turn on, the alpine should have 2 blue wires, one is solid blue for power antenne/antenne booster (this only turns on when you have tuner selected/shuts off when you switch to cd)
the other is blue w/white stripe to turn on amplifiers.
Old 12-03-2005, 05:50 AM
