76 912 915 transmission, is it a 7:31 R&P?
also, are all the gear ratios different-thanks-Bill
Old 01-07-2006, 11:34 AM
ive got a 4 speed from a 72 that i can use for parts, can the 76 be retro fited with a mech speedo, or how hard is it to wire for an electronic speedo? thanks-Bill
Old 01-07-2006, 12:27 PM
the 4 speed is in about 4 boxes...
Old 01-07-2006, 12:28 PM
Hoffman912's Avatar
bill, you shoudl go to 912bbs.org and ask this on the 912E forum, they will give you the right answer.
Harry Hoffman
68' 912 Coupe 'Fritz' burgundy red (6808) | 67' 912 Coupe 'need parts?'
912 Registry charter member #912R0195-C | Early 911S Registry member #2070
http://hoffman912.blogspot.com/
Old 01-07-2006, 10:56 PM
If you convert to a gearbox with an electronic speedo drive, it's just a matter of installing the corresponding electronic speedometer. Remove the existing speedo drive cable from its sheath, then route the sender signal wires through the sheath up to the speedometer. The gauge also needs 12V.
Sherwood
Old 01-07-2006, 11:54 PM
thanks guys, i bought a 76 912 e trans yesterday, to put in a72 rs clone that i am working on. glad to hear its no bigdeal to convert to electronic. thanks-bill
Old 01-08-2006, 07:00 AM
thanks noah, i understood-see ya-bill
Old 01-08-2006, 09:22 AM
