arbita1's Avatar
Corner Balance Scales
If I was to "hypothetically" buy a set of corner balance scales, would the 1,100 lbs scales be sufficient or would I need to get the 1,500 lbs ones?
These are the Accuset scales from Long Acre.
Matt.
83 911SC
85.5 944 NA - Sold
Old 10-26-2007, 03:14 PM
ianc's Avatar
Well, since you'll need one at each wheel, four 1100 lb scales would add up to a total of 4400 lbs. More than enough to do a 911. If I'm understanding the question correctly that is...
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 10-26-2007, 03:22 PM
Less brakes, more gas!
euro911sc's Avatar
If each scale can handle 1100 lbs (total car wt. 4400lbs) you're fine... if that is the total max wt. you don't want those... I can only assume you mean the former.
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
arbita1's Avatar
I know total capacity is fine. I'm not expecting the 911 to weigh more than 2,900 lbs.
I'm asking if I will need more than 1,100 lbs at any one wheel. I don't think I will, but wanted to check.
Matt.
83 911SC
85.5 944 NA - Sold
Old 10-26-2007, 03:38 PM
Let's assume you have a new Porsche.
At approx. 3500 lbs., 60% of that weight sits on the rear wheels. Thus,
60% x 3500 = 2100 lbs. / 2 wheels = 1050 / rear wheel - borderline weight for an 1100 lb. scale.
An early 911 is about 1000 lbs lighter making the 1100 lb. scale more than adequate for anything up to about 2000 lbs per end or 4000 lbs. total.
Hope this helps,
Sherwood
Old 10-26-2007, 09:57 PM
burgermeister's Avatar
I'd check to make sure the scale can handle an overload without becoming damaged. When you drive the car onto the scales somewhat unevenly, or you bounce the car a bit, or if you're using a jack the car is lowered unevenly or suddenly, you could easily generate an additional few hundred pounds on one wheel, which might get you over the limit on the rear of the car. I'd think they would put a metal stop of some sort in the scale so it won't become damaged, but manufacturers of all sorts of products are very creative cost cutters these days....
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 10-27-2007, 07:03 AM
Great. Internet connection fart. Sorry bout that, it's Verizon EVDO's fault.
3.2 CAB's Avatar
I replied to you on this same question on Rennlist. Same reply still goes.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 10-27-2007, 07:28 AM
