electronic speedo and early 901 trans?
hello all,
Can a electronic speedo from a 75 or newer car be made to work with my early 901 mechanical speedo trans??.... PS its in my 914... Thanks Josh
1972 914-6 in the works..... 2003 Ford E-250 "work horse" 2004 Yamaha V-star Classic 1100 "early mid life crisis" 2005 Scion XB "Gas sipping" 1978 Siedelmann S25 "Ataraxia" |
1976 models were first to get an electronic speedo ...
Two methods can be used: 1. VDO has a converter to change from cable drive to an electronic signal for the '76 and later speedos. 2. An opto-interrupter can be mounted to the side of the differential cover, and a slotted wheel can be bolted to the CV-joint to generate eight pulses per revolution of the CV and axle. Here are some typical opto-interrupter sensors: http://www.allelectronics.com/cgi-bin/category.cgi?category=435&item=OSU-54&type=store http://www.goldmine-elec-products.com/prodinfo.asp?number=G14268&variation=&aitem=12&mitem=39 Here is the Omron data sheet: http://oeiwcsnts1.omron.com/pdfcatal.nsf/PDFLookupByUniqueID/8B0566C69A59D72A86256FC80071B5E7/$File/D21EESX460P10305.pdf?OpenElement Here is the Omron Tech Notes document explaining the operation and design guidelines: http://oeiwcsnts1.omron.com/pdfcatal.nsf/PDFLookupByUniqueID/EFFD47E704CCD33586256FC8006311C6/$File/C21photomic0305.pdf?OpenElement
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' Last edited by Early_S_Man; 12-05-2005 at 10:04 PM.. |
Hmmmmm.....build my own eh? My creedo is just that when cost effective. How hard would the wiring for that be? I think I could manage the slotted wheel end of it.
or what would it take to convert the 911 tranny sender? Thanks Josh
1972 914-6 in the works..... 2003 Ford E-250 "work horse" 2004 Yamaha V-star Classic 1100 "early mid life crisis" 2005 Scion XB "Gas sipping" 1978 Siedelmann S25 "Ataraxia" Last edited by degreeoff1; 12-05-2005 at 06:49 PM.. |
Hey - think of the wt. savings! You are replacing a mechanical cable with a wire.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
