Guest
Posts: n/a
I have been told that later model cabrio roofs will fit onto earlier Cabrios - and give a cleaner looking line?
Has anyone tried this? What model roofs can be used on a 1985 911 Cabrio? Thanks |
Convert to a Targa! Then it only leaks aaround the door seals. Oh I forgot converts do that also.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not. 2012 BMW 528i (wife's) 2007 Toyota FJ (rain and off road days) |
I have an '83 with a 993 top. Smooth, cleaner and more updated look. However, you would develop a blind spot. Can't find the appropriate pics though.
Sorry. I do not have a back-view. |
Guest
Posts: n/a
Hi,
thanks for posting the photos. Do you have to change the hood frame in order to fit a 993 roof? or will the 993 roof fit onto a sc / 3.2 Cabrio frame? THanks Tim |
When you purchase the top you need to specify you want the 993 style for an 85 year.
Jim Dowty 97 911 Coupe (Forest Green metalic, sunroof, leather) PCA RSR region Insurance chair and Board member Gruppe B #309 |
No changes to the frame was required. May I again stress the 'blind spot!' Consider this, and if you do decide to get the 993 top, learn to use your passenger side mirror a lot and/or turning your head a lot. BTW, my car is the first Cab ..... a 1983! |
