Noise Canceling Horns? Acoustic Guys?
Did I correctly orient these hellas in my fender? Is it possible that the orientation could effect the volume of these horns? I want to make sure they're as loud as possible!
With speakers you can create cancellation by wiring them oppositely. I'm only guessing that unless you pointed the horns at each other at the right distance appart the only way you might "cancel" them would be to wire them wrong. But I'm no expert.
One high, one low and they're wired up w/ a relay. Thanks.
Yep, with 2 different tones they are much less likely (or not at all) to experience destructive interference
They'll be louder if you move them to the passenger compartment.
![]() Okay, maybe I'll add something else. Visualize the path of the sound coming out the horn and where it will go. Follow the path like a pool ball, banking off the ground. If they are pointed directly at the ground the sound may bounce back up into the same area and not be very loud outside the fender. If you point them at the ground at an angle, maybe more of the sound will bounce off the ground in a direction at an angle coming out from under the car. Aim them where you want them to be loudest as they are at least a little directional. straight down and back up v^ v^ v^ v^ v^ v^ v^ v^ v^ ___ down at an angle and back up at an angle \-------|-------/ ->------|------> --\-----|-----/ --->----|----> ----\---|---/ ----->--|--> ------\-|-/ ______________ Have fun,
Rob Channell One Way Motorsports 1979 911SC mostly stock ![]() 1972 911T Targa now with a good 2.7 ![]() 1990 Miata (cheap 'n easy) 1993 C1500 Silverado (parts getter) Last edited by Rob Channell; 12-05-2005 at 06:55 PM.. |
Good thinking Rob. valid point.
except... the sound will not be very directional at the dominant frequencies -- won't hurt tho
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Rob Channell One Way Motorsports 1979 911SC mostly stock ![]() 1972 911T Targa now with a good 2.7 ![]() 1990 Miata (cheap 'n easy) 1993 C1500 Silverado (parts getter) |
The horns will be way higher than that -- maybe in the 1kHz range or so. Get a test record and match the freqs. if you need to.
