Hads my 3.2 missing parts?!
Hi my 85 3.2 Carrera engine looks doiferent from some others; as you look in to the engine bay other cars seem to have a plastic shroud on the left side at the top (nearside). Mine doesn't have this sorry for my limited knowledge.
Old 12-10-2005, 09:48 AM
I think you mean the heater part that comes from the hotair blower. Maybe the p.o backdated the heating system. Post a pic of you engine bay and we will have a look for you
87 Carrera Backdate
Old 12-10-2005, 09:59 AM
The car has autoheat?
Old 12-10-2005, 10:00 AM
PorscheGuy79's Avatar
The car can still have the auto heat controls and be backdated.
Matthew
“Sometimes the questions are complicated and the answers are simple.”
Old 12-10-2005, 10:01 AM
The heater only blows hot.....have checked the flaps but they are free and easy! Si I assume the dreaded box by the handbrake is brocken. Thanks Ian
Old 12-10-2005, 10:03 AM
Not terribly uncommon. There is a little servo in there with an arm that moves the heater boxes, it can break and was broken on my SC system.
Matthew
Old 12-10-2005, 10:04 AM
Like Matthew said could be the servo or maybe it,s just a loose connection inside the box. The servo makes enough noise to hear it operating. Can you hear something from the box when you switch on the heating ?
87 Carrera Backdate
Old 12-10-2005, 10:11 AM
It's tucked away so can't check but I don't think so.
Old 12-10-2005, 10:16 AM
take the four allen bolts out at the sides of the box and check connections and offcourse check fuses first.
87 Carrera Backdate
Old 12-10-2005, 10:21 AM
Dutchie many thanks you have put my mind at rest regarding my engine.
Old 12-10-2005, 10:24 AM
The part I was trying to describe is pictured in the post "Tom and Jimmys rebuild done" 5th photo down, mine doesn't have the plastic cowling should my 85 3.2 car have this and what is it? Thanks Ian.
Old 12-10-2005, 10:37 AM
Could you take a picture of you engine. I know what part you say you are missing but im trying to see if a PO had installed a different type of heat system. The only way I can tell is if you post a pic of the engine bay.
Matthew
Old 12-10-2005, 11:07 AM
Pictures are your friend!
Old 12-10-2005, 12:38 PM
