-   -   Hads my 3.2 missing parts?! (http://forums.pelicanparts.com/porsche-911-technical-forum/255528-hads-my-3-2-missing-parts.html)
CarreraUK 12-10-2005 09:48 AM
Hi my 85 3.2 Carrera engine looks doiferent from some others; as you look in to the engine bay other cars seem to have a plastic shroud on the left side at the top (nearside). Mine doesn't have this sorry for my limited knowledge.
Dutchie 12-10-2005 09:59 AM
I think you mean the heater part that comes from the hotair blower. Maybe the p.o backdated the heating system. Post a pic of you engine bay and we will have a look for you :)
CarreraUK 12-10-2005 10:00 AM
The car has autoheat?
PorscheGuy79 12-10-2005 10:01 AM
The car can still have the auto heat controls and be backdated.
CarreraUK 12-10-2005 10:03 AM
The heater only blows hot.....have checked the flaps but they are free and easy! Si I assume the dreaded box by the handbrake is brocken. Thanks Ian
PorscheGuy79 12-10-2005 10:04 AM
Not terribly uncommon. There is a little servo in there with an arm that moves the heater boxes, it can break and was broken on my SC system.
Dutchie 12-10-2005 10:11 AM
Like Matthew said could be the servo or maybe it,s just a loose connection inside the box. The servo makes enough noise to hear it operating. Can you hear something from the box when you switch on the heating ?
CarreraUK 12-10-2005 10:16 AM
It's tucked away so can't check but I don't think so.
Dutchie 12-10-2005 10:21 AM
take the four allen bolts out at the sides of the box and check connections and offcourse check fuses first.
CarreraUK 12-10-2005 10:24 AM
Dutchie many thanks you have put my mind at rest regarding my engine.
CarreraUK 12-10-2005 10:37 AM
The part I was trying to describe is pictured in the post "Tom and Jimmys rebuild done" 5th photo down, mine doesn't have the plastic cowling should my 85 3.2 car have this and what is it? Thanks Ian.
PorscheGuy79 12-10-2005 11:07 AM
Could you take a picture of you engine. I know what part you say you are missing but im trying to see if a PO had installed a different type of heat system. The only way I can tell is if you post a pic of the engine bay. :)
89911 12-10-2005 12:38 PM
Pictures are your friend!
