Recaro Sliders
OK, this should very easy to install Recaro sliders on Recaro seats. But I'm not sure if they are right side up. Should the adjusting bar be pushed down or pulled up to slide the seat?
The bar doesn't want to pull because of plastic seat bottom is in the way. And if installed to push it down the rails hit the lower part of the plastic back rest.
Old 06-12-2008, 10:13 PM
David in VA's Avatar
The bar should pull up. I have Recaro sliders with Pole Position seats and have no clearance issues.
'87 911 Coupe
'95 911 Coupe
'04 911 GT3
'98 Jeep Wrangler
Old 06-13-2008, 05:03 AM
That's what I assume, I'll need to trim a couple of plastic ribs about a half inch.
Old 06-13-2008, 07:27 AM
haycait911's Avatar
what about spacing the sliders off the bottom of the seat a bit, would save cutting.
Old 06-13-2008, 07:47 AM
