WydRyd's Avatar
Question 3.3 EFI Turbo: Compression Test Results
Thought I'd post these numbers in a new post, since I'm all over the place these days trying to diagnose my low idle/stalling/power-loss issue
OK, these are the numbers I get doing a cold compression test:
# 1 = ~100
# 2 = ~110-115
# 3 = ~110
# 4 = ~110-115
# 5 = ~110-115
# 6 = ~110-115
I know compression tests should be done warm and is only a rough guide to the condition of the engine internals. If I had a compressor and leakdown tester, that would be the next test I'd be doing on Cyl # 1.
Anyway, my main concern with these results is Cyl # 1
Whilst it isn't significantly lower than the others (~10% variance), it raises some cause for concern and further troubleshooting.
I know the typical causes for lower compression could be attributed to:
- Worn rings
- Cracked ring land (BTDT!)
- Pulled head stud(s)
- Valves
- Head gasket
Question:
If I had only one blown out head gasket, could it be causing low idle/stalling?
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 12-09-2005, 03:37 PM
I would not be worried about No.1....hard to determine cylinder health on a cold motor...was the throttle open?
100psi is inline with your other numbers....do not worry.
Which EFI are you using?
Yasin
Old 12-10-2005, 09:01 AM
WydRyd's Avatar
Throttle wide open.
Using the OEM Motronics EFI.
So I guess thehunt is still on
Must be either fuel system or ignition
Merv
'89 911 Turbo Cab
Old 12-11-2005, 06:06 PM
porschett's Avatar
My #1 had low compression numbers compared to the rest also. Turned out to be a broken #2 compression ring. Played around with the boost controller too much and hit overboost a couple of times.
This may not be your problem, but just FYI.
David Nguyen
1987 930: 2700 lbs, 408 RWHP/405 RWTQ
930 pics: http://alturl.com/899f9
930 Engine rebuild pics: http://alturl.com/25qcy
Old 12-13-2005, 10:20 AM
