Wiring Diagram Help
I have an 83 ROW cab that I recently wrecked.
I just bought an 81 US Targa. I'm thinking of swopping the engines because the ROW was recently rebuilt. The only wiring diagram I've seen is the 82 USA diagram which seems to be pretty common. I know the 81 has an external regulator. I'm trying to figure out what else needs to be reworked in the 14 pin connector. I assume I just leave the CIS connector un hooked or remove the controller and the herness. Can anyone help with this? The ROW is k-basic so it has no controller. Probably more simular to a 79 us. Also the ROW has the speed limiting rotor instead of the electronic one.
Bill Miller 81 Targa Guards Red 3.6, M&K 1 out, S4 brakes 83 ROW CAB Rubinrot Metallic (RIP) |
SC Wiring Diagrams....
Bill,
Got some wiring diagrams from '74 to '82SC USA models. Don't have a scanner so will do with photo copies. Send reply to ATD911@hotmail.com. Hope this will help. Tony |
Thanks Tony, but hold tight. That seems like a lot of work. I'm sure someone here has them already in electronic form.
BTW, where did you get them?
