XLR8'd Member
David 84 911's Avatar
Question Shifter Bushings good when engine is off
Started taking apart my shifter to replace the bushings and realized it shifts perfectly when car is not running.....
When driving it's a different story, hard to shift. Should I even be changing the bushings?
David (mechanic wanabe)
2002 Carrera 4S (replacement for an 84 coupe)
06 Acura CSX (wife beater)
05 Acura MDX (toy hauler)
http://www.pelicanparts.com/gallery/david_84_911
Old 12-13-2005, 05:07 PM
Where is that wrench?
EdT82SC's Avatar
This is normal. I would replace them still. And while you are at it adjust the clutch cable. If you can't adjust within spec then replace it. Drain and re-fill the transmission with new gear oil. Doing all this is pretty cheap, and solves a lot of transmission/clutch issues.
Ed T.
1982 911SC
Porsche Wallpaper
Old 12-13-2005, 06:54 PM
