915 trans rebuild list?
I am planning to rebuild my transmission. I hear a strong noise, which after reading many posts hear I aasociate with bearings being worn.
Quote from JW which desribes my problem perfectly: "that's your typical mainshaft bearing noise. car stopped, clutch engaged, idling in neutral, noisy, push in clutch, noise decreases or goes away" I don't have any problems with shifting, no grinding at all, so i wonder if I should replace anything other than the bearings. I have never done a trans rebuild before, so I am not sure which parts i should get. Can anyone help me with a parts list for this job? (assuming that I will replace only the bearings) Thanks |
This has been covered before. Try a search. Here is a good thread to start with. It gives about as much info as you could hope for from a thread about rebuilding a transmission.
http://forums.pelicanparts.com/porsche-911-technical-forum/159059-cant-shift-into-first.html |
Thanks Ed. Yeah, i did quiet some reading but I am still confuse about the parts that i will need. Which bearings i have to get? Which seals, and so on.
The situation is a little bit complicate. I will be moving out of the US at the end of the month...going to Guatemala. I just finish a 7 months long project on my car including engine swap, widebody kit, paint job, etc, etc. But, I need to rebuild the trans. I will not have time to do it before leaving, so I am planning to buy the parts here and take them to do the rebuild once in there. I don't expect to have too much Porsche parts availability in Guatemala, and prices will be much higher. So, I would like to have the must-have parts list for a rebuild to take from here. Thanks, Mario |
| All times are GMT -8. The time now is 07:18 PM. |
