ignition hestation
1987 carrera...when I turn the key to start the engine, I some times get a slight hesitation (no reaction) and then the starter starts turning and the motor comes to life.
Most times it will turn right away and other time as above...
Any suggestions as to why and what should be done?...Thanks
Old 08-30-2013, 03:52 AM
76 911S Targa
Not enough current to starter solenoid. Most likely dirty connections: ground at battery, ground at chassis/transmission. Check battery voltage to see if it is fully charged.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 08-30-2013, 07:22 AM
ignition hesitation
Thanks...battery is new and fully charged...it is probably the connections you mentioned...
the red charge lights and buzzer do come on instantly but not the cranking
Old 08-30-2013, 07:32 AM
