-   -   returning Weltmeister short shift back to stock (http://forums.pelicanparts.com/porsche-911-technical-forum/256305-returning-weltmeister-short-shift-back-stock.html)
Vin-barrett 12-15-2005 06:15 AM
The PO of my car installed the Weltmeister short shift which I'm not too fond of.
I do have the original shiftlever.
Is this all I need to return to the stock shifter? When I see the WSS kit advertised it looks to only include a lever , spacer and hardware.
Could I just remove the spacer and replace the stock lever to return the car to stock? Or is there something else I need as well?
Maybe the stock hardware (shorter bolts)?
Vinny
johnsjmc 12-15-2005 07:18 AM
You remove the spacer plate and reinstall the original handle. The longer bolts should probably work (extra length will hang into the tunnel about 1/4 ". If I recall the hardest part will be transferring the shift knob without damage. Then reset the shift linkage at the swivel connector would be recommended.
Vin-barrett 12-15-2005 07:30 AM
Thanks for the reply John.
Looking forward to getting that thing out of the car (and adding a Seine gateshift).
Vinny
911FL 12-15-2005 07:34 AM
I did this on mine and had to cut the rear bolt down to fit properly. Otherwise it was hitting and binding the linkage leading to the rear.
Vin-barrett 12-15-2005 07:39 AM
Thanks Dan
I will certainly keep that in mind.
Vinny
