Somatic Negative Optimist
Gunter's Avatar
Question Green wire SC-ignition question
I believe in spare parts and would like to get the part/adapter that people use when experiencing problems with the green wire going from distributor to the Bosch CDI module.
What is this thingy and what is involved to install it?
Many thanks.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 12-15-2005, 08:42 AM
I think this is your part. Available from our host for $27.
http://www.pelicanparts.com/cgi-bin/smart/imgdsply.cgi?pn=93060290701-M14
Tom Butler
1973 RSR Clone
1970 911E Restoration in Progress
Old 12-15-2005, 02:19 PM
Senior Member
Superman's Avatar
Yep, that's it. And you'll need one of those square bosch "fuel injector" connectors to install on the green wire.
Old 12-15-2005, 02:35 PM
Gunter's Avatar
Thanks, guys, I looked at the part, and some pictures.
So, the new part plugs in to the distributor, then it has a standard plug (Like the one on the WUR or AAR) on the other end, fine.
How do you connect this "Fuel injector plug" to the old green wire in the harness loom?
The old green wire has an inner small wire, and a shielded cover like a coax cable. They cannot be mixed up going to the module!
Help!
Old 12-16-2005, 06:48 AM
Gunter,
JW did a thread on this and I looked but could not find it. I know I bought a new FI connector and wired it in so that it was a simple plug in. Here are a couple of pics one is of my rebuilt unit and another of a stolen pic off the board
Ben
914-6 2.4s GT tribute.
914-6werkshop.com manufacturer of 914-6, GT, Conversion parts
Old 12-16-2005, 07:46 AM
Senior Member
Superman's Avatar
I'm not sure why this wire would need to be a coax and I'm pretty sure switching wires makes no difference.
Old 12-16-2005, 07:57 AM
it does make a difference. the spark would have to jump sideways across a wider gap from rotor to cap terminal, instead of straight across at the closest point. here's the old thread.
wierd 78 SC distributor problem.
206 637 4071
Old 12-16-2005, 08:04 AM
Gunter's Avatar
Cool
Thanks everyone.
Super: Loren will come down on you.
JW: I'll make sure not to mix up (switch) the wires.
mb911: Great pictures and a clean job but, when there is a 6-pin connector to the CDI module?
Do you peel back the green outer coating on the old wire and crimp the outer coax-braiding to one pin of the FI connector, and the inner wire to the other pin?
Or, do you run a complete new wire from the FI connector up to the 6-pin plug, find the right pins and somehow connect the new wire to the appropriate pins?
This issue might be good for a tech article.
Old 12-16-2005, 08:46 AM
I ran a new one but I use MSD ignition . I would run new wire and coax if possible and split it and use a new fuel injector connector. Before I did this I split the coax(oem green wire) and used the outer sheild in one connector pin and the used the other inner wire in the other connector pin. It worked but I felt that the whole wire needed to be replace but it should be mentioned when I bought my engine the 6 pin connector had been cut off along with most of the wiring harness so I replaced most of the connectors my way(very clean with the exception of the EFI wiring as seen in this pic
With that good luck and happy holidays
Ben
Old 12-16-2005, 08:58 AM
"Do you peel back the green outer coating on the old wire and crimp the outer coax-braiding to one pin of the FI connector, and the inner wire to the other pin?"
you got it.
206 637 4071
Old 12-16-2005, 10:43 AM
Lorenfb's Avatar
"the spark would have to jump sideways across a wider gap from rotor to cap terminal, instead of straight across at the closest point." - johnwalker -
Not true! It's correct to state that the polarity is critical, but not for that reason.
With the polarity reversed, the CDI unit is triggered at the wrong time causing
an initially retarded spark advance. This retarded spark then changes with
RPM and thus affects the overall desired advance curve.
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 12-16-2005, 05:22 PM
Not true! It's correct to state that the polarity is critical, but not for that reason. With the polarity reversed, the CDI unit is triggered at the wrong time causing an initially retarded spark advance. This retarded spark then changes with RPM and thus affects the overall desired advance curve. [/B]
Loren is correct,..I see a 10-12 degree retard with my timing light when the polarity gets reversed.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-16-2005, 05:42 PM
and hence, the spark is delivered after the rotor has passed the cap terminal.
206 637 4071
Old 12-16-2005, 06:23 PM
Gunter's Avatar
Interesting stuff!
mb911: Wow! That sure is different.
Loren: How about doing a short Tech Article on this and submitting it to the archive?
Especially since the polarity is important when doing the rewiring.
JW: Is it true that the inductive trigger in the distributor can be installed the wrong way? I seem to recall one of your posts on this.
Old 12-17-2005, 07:50 AM
ChrisBennet's Avatar
Rather than start a new thread I thought I would resurrect this one.
On the engine side connector that goes to the CD box, I have the scope hooked up positive to green wire, negative to "black" wire which I assumed was the (-) shield. But I don't know and this is why I'm asking. This is an older 930 harness before they went to the replacable "green wire".
Is this the waveform I should see (positive scope lead to green wire above)?
I made up a connector for the MSD box to attach to the factory harness with this assumption. The old wiring harness may have had these reversed and I'm making no assumptions that the pins wiring on the factory connector hasn't been messed with.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i Coupe
Old 03-12-2007, 12:37 PM
Lorenfb's Avatar
Check here www.systemsc.com/waveforms.htm under "Reference/Pickup Signal".
Have Fun
Loren
Systems Consulting
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 03-13-2007, 08:53 AM
Thanks Loren. Looks like I have the correct wiring/signal.
-Chris
'07 BMW 328i Coupe
Old 03-13-2007, 10:19 AM
Since this thread is over 10 years old, I wonder if by now some one has written a DIY regarding making an "extension" cord to work w/ 930.602.907.01 and hooking it up to the plug?
Richard
searching for engine (case) 903742
Old 11-09-2018, 09:15 AM
ROW '78 911 Targa
timmy2's Avatar
Distributor Green wire loose and frayed
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, Bitz kit EFI.
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 11-09-2018, 12:09 PM
Thanks!
Richard
Old 11-09-2018, 12:32 PM
