WydRyd's Avatar
Question Testing the Motronic ICV/ISV?
I checked the ohmage between the two outside pins and the centre pin on the ICV/ISV and it measures 20 ohms.
I read in historical posts that this is what it's suppose to be, however, does it necessarily mean the ICV is 100% OK?
Could the ICV still be faulty but have proper resistance values?
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 12-15-2005, 04:26 PM
WydRyd's Avatar
Does anyone have any pics of a stripped down ICV/ISV?
Merv
'89 911 Turbo Cab
Old 12-15-2005, 06:14 PM
87coupe's Avatar
I would take it off, clean thoroughly, make sure it can open & close smoothly, put it back in and see where you stand. If your having problems with it that's the first thing I would do.
ßrandon
Old 12-15-2005, 06:25 PM
ianc's Avatar
WydRyd,
What makes you think it's faulty? The Bentley has some good test procedures for this part; do you have it?
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 12-15-2005, 07:19 PM
WydRyd's Avatar
I only suspect it's faulty because the engine won't idle and dies after 3-5 seconds.
I checked ignition, fuel pressure, compression, AFM etc and they all look OK. Only other thing affecting idle is the ICV or a big vacuum leak somewhere
No I don't have the Bentley manual........... yet!
EDIT: Oh, I tried banging on the ICV with a wrench whilst the car was idling. Made no difference too. Couldn't be THAT siezed up, right?
Merv
'89 911 Turbo Cab
Old 12-15-2005, 08:05 PM
87coupe's Avatar
I would also check the Throttle position microswitch.
ßrandon
Old 12-15-2005, 08:16 PM
Nine9six's Avatar
Or check the o2 sensor. I cleaned my ICV and replaced my o2. That fixed my idle problem. How many miles on your sensor?
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 12-16-2005, 05:07 AM
DonMo's Avatar
Send a message via AIM to DonMo Send a message via Yahoo to DonMo
Don't forget to try the age old Carrera favorite leak point. The intake manifold bolts are notorious for coming loose. I routinely tighten mine. Use the intake cleaner to spray around the base of the intake to see if the idle changes. Mine did.
DonMo
1984 911 Carrera Targa
3.2 liter, SSI's, Dansk 2 to 1, Steve Wong Chip
Columbia, SC
"Go Hokies"
Old 12-16-2005, 08:48 AM
ianc's Avatar
DonMo has a good suggestion, but you would want to take the ISV out of the picture before doing this though...
ianc
Old 12-16-2005, 10:06 AM
WydRyd's Avatar
Yes I'm considering this too, however, from what I've read from John Walker's posts, many of these blown out/sucked in inlet manifold gaskets are the bottom ones, which is too low below the fan shroud for the carb cleaner to reach.
I'll rule out the ICV completely fist before removing my whole intake
Merv
'89 911 Turbo Cab
Old 12-16-2005, 02:13 PM
WydRyd's Avatar
Problem found!
See FINALLY FOUND THE CAUSE of my low idle!!!
Merv
'89 911 Turbo Cab
Old 12-16-2005, 03:48 PM
ianc's Avatar
You might try just retorquing the intake bolts and see if that will cure the leak...
But probably not.
ianc
Old 12-16-2005, 03:55 PM
WydRyd's Avatar
Yeh I tried that but it didn't make much difference at all.
Might as well rip off the whole intake and do all 12, just to be 100% sure
Merv
'89 911 Turbo Cab
Old 12-16-2005, 04:01 PM
ianc's Avatar
That's what I would do... Don't know how tough that is with the engine in the car. On my SC it was a beeotch...
ianc
Old 12-16-2005, 04:19 PM
