Headlight Washer
Anyone have an artivcle on how to repair the headlight washer nozzles and hoses. Pump works fine
Recreational User
I don't know of an article, but last summer I had my bumper off and I messed around with all of that stuff, including replacing the washer pump.
Aside from the pump failing, the next most common problem is clogged check valves. I replaced those as well while I was in there even though they were probably OK. The only difficult thing in the whole job was R&R'ing the bumper. |
Headlight Washers
Try a title search for headlight sprayers. I posted a few tips related to the job a while back, the search should locate it.
Good luck, Gordo
Don "Gordo" Gordon '83 911SC Targa |
Inside the trunk there are two hoses that hook up to the pump in front of the battery. They tend to come off. I would look at that first. Very easy fix...
Bill 997.2 |
Understand that the headlights need to be "on" for it to work..otherwise you'll be trouble-shooting forever !!!
might not be "your" problem...but this may be of use to others searching out solutions... Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
