How many cranking amps?
I have been told most cars produce around 13-13.8 amps, and should not drop below 13 amps. Just curious, how many amps are actually needed to crank the car? Thanks.
Re: How many cranking amps?
Hope this helps, Sherwood |
Thanks, Sherwood. I sure appeciate your time. Bill
The cold cranking amps really depends on where you are located. That's what you should really look at when buying a battery. I live in Michigan and I wouldn't run anything less than 500 cold cranking amps (CCA). Summer time anything works, but in the winter you gotta have lots of CCA.
Both my P-cars have batteries from the PO and I only drive them in the summer. But when it's time to change them out I'm going to get a battery around 300 CCA. Unless you live somewhere warm all year around I wouldn't go with anything less. Good Luck!
Bill 997.2 |
Somatic Negative Optimist
Birmingham Bill:
If you don't have a Repair Manual for your 964, get one and read it from cover to cover. It'll help you understand your car much better.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
"....and I wouldn't run anything less than 500 cold cranking amps (CCA). Summer time anything works, but in the winter you gotta have lots of CCA."
I agree, but to avoid any confusion, the CCA rating is the capacity of a battery to create current at low temperature. The current required to rotate the starter motor is an amount independent of the battery rating. Sherwood |
