SC Targa Guys - help with a measurement please
Could someone with an SC Targa give me the measurement between the upper suspension mounts. Inside lip to inside lip would be great.
Thanks.
Terry
1981 SC
Old 12-24-2005, 08:16 AM
Driver Ed's Avatar
I just measured mine ('82 SC) and got exactly 36 inches.
2000 Porsche 911
1982 Porsche 911 SC Targa
Old 12-24-2005, 08:37 AM
Porsche Crest
I also get 36 inches [79sc]
Old 12-24-2005, 09:12 AM
Thanks Guys. My issue is that I have a '77 S Coupe that I'm swapping parts out to an '81SC Targa. The distance between the 77 is 36-5/8" and the 81 is at 35-3/4" (you guys are at 36"). Because of this, I have extreme negative camber in front-end and what appears to have no more adjustment. Man, I'm really puzzled.
Terry
1981 SC
Old 12-24-2005, 11:56 AM
The shorter distance will give you neg camber but only a 1/4" between both towers. I would try a little jacking with a strut brace or even a small hydraulic jack. How does your hood fit?
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 12-24-2005, 12:52 PM
johnsjmc,
Hood fits good. Pushing it out a hair will not hurt the hood alignment and may do the trick with the camber. What puzzles me, is that the 77 is almost an inch wider but all parts for the front suspesion are the same for both years (according to PET). An inch of difference sounds like a lot to me, but alignment is not my expertise. I do have the car lowered in the Euro height area (f 25.5, r 25). If I raise it some, it should stand the tires up. These parts should be inchangable, correct?
Terry
1981 SC
Old 12-24-2005, 01:36 PM
An inch is alot I was refering to the 1/4 " that the 82 varies from the 36 " posted. What measurement diff do you have from the fender edge to edge on both cars? If the towers have sagged I would expect the fender edge to move with them. Alignment is set by moving the shock in the tower top. If you run out of room on the sloted holes before you get your camber in spec then something has moved the tower tops as the bottom distance should remain set by the length of the crossmember.(If no bent parts from a collision )
1995 993 coupe
2012 Boss 302
Old 12-24-2005, 01:59 PM
I measured both cars straight across over the top of the towers, in the middle. Both are right at 40-3/8". Can the towers be pushed out without effecting the fender edge? That might be all I need. I know the 81 has been in some kind of front-end wreck. I have replaced the front pan. It went in just fine and diagonally measured up good with rear cross tube and front suspension cross support piece. The top of the struts are adjusted out as far as they will go. The front suspesion from the 77 does not appear to be bent.
Terry
1981 SC
Old 12-24-2005, 05:19 PM
As the front fenders are bolt on. I would loosen the fender edge bolts and spread the towers apart with a brace .Keep an eye on the fender /hood width..Hopefully when you tighten down the fenders they will keep the towers where you put them. The 911 is fairly stiff on the front end but the towers do move or there wouldn,t be such a big aftermarket in diff styles of shock tower braces.
1995 993 coupe
2012 Boss 302
Old 12-24-2005, 06:27 PM
I think that sounds like a good plan of attack. After we get all of the Christmas stuff completed, I'll give it a try. Thanks to all of you guys for the info. Have a Happy Holiday.
Terry
1981 SC
Old 12-24-2005, 08:38 PM
On a slightly different topic .I need a pair of rear swaybar droplinks for a 1977 Does your doner car want to give them up??
1995 993 coupe
2012 Boss 302
Old 12-24-2005, 08:49 PM
I'm planning on using them. Sorry.
Terry
1981 SC
Old 12-26-2005, 06:03 AM
SC Schrauber's Avatar
36" as well
81 SC, www.frankschroeter.com
Old 12-26-2005, 09:11 PM
