-   -   Which set up is more aggressive? (http://forums.pelicanparts.com/porsche-911-technical-forum/257323-set-up-more-aggressive.html)
RSBob 12-21-2005 03:47 PM
'Agressive' is purely a relative term. Set-up 1, or 2, or they are so close to being the same, there is no real diff?
Set-up 1
L front R front
Camber -1.4 -1.6
Caster 6.5 6.2
L rear R rear
Toe .07 .08
Camber -1.5 -1.5
Set-up 2
L front R front
Camber -1.4 -1.45
Caster 5.98 5.82
L rear R rear
Toe .10 .08
Camber -1.6 -1.74
RSBob 12-21-2005 06:54 PM
"Anyone? Anyone? Anyone?" "Bueller. Bueller. Bueller." ka-bump!
Steve@Rennsport 12-21-2005 07:07 PM
Rick:
FWIW,....
Setup 1 will have a tad more oversteer
Setup 2 will have a tad more understeer.
Both setups look optimized for tracks with predominately left turns.
Your final alignment settings will depend on what tires you use, how use the car, and how much range of adjustment you can get at your ride height.
Hope this helps, Sir.
Jgordon 12-22-2005 06:26 AM
Yep, I agree with steve. ;)
aircooledsonly 12-22-2005 08:39 AM
what rim width and tire size are we dealing with here?
Craig 930 RS 12-22-2005 08:41 AM
What track and what HP motor? Tires?
Ferris....we need more info
RSBob 12-22-2005 09:05 AM
Track is Pacific Raceways but would like to do PIR.
Tire size 205 /55/15
Motor is modified RS Spec 2.7 - 220hp at flywheel
Craig 930 RS 12-22-2005 10:53 AM
What tires?
Wil Ferch 12-22-2005 11:11 AM
I wonder if *anyone* here is good enough to notice and evaluate a blind-folded side by side test...( not *really* blindfolded...you know what I mean). I'd say you'd be hard pressed to know the difference, especially if you don't have solid pivot points ( heim -joints) on your car.
Wil
Steve@Rennsport 12-22-2005 11:15 AM
Wil:
IMHO, VERY few people will be able to discern any difference in handling between those two alignment setups. :)
Tires and tire pressures make a far far bigger difference,.....
Craig 930 RS 12-22-2005 11:25 AM
Exactly. I am attempting to come up with a setting for him based upon:
Tires & size
Actual use - track/street etc
HP
As Steve said to me a few years back:
"What Is Your Mission?"
Hey Bob, post a pic of your car. I'm sure I've seen it -
Craig 930 RS 12-22-2005 11:39 AM
I prefer:
-3.0 rear, -2.2 to -2.6 up front.
Slight toe in in the rear, slight toe out in front.
Wil Ferch 12-22-2005 11:52 AM
On the basis of RsBob's opening remarks.... he's only asking if there is a difference between these two settings...and he's (seemingly) not asking what OTHER set ups may be "better" ( whatever that means..depends on the "goal").
On that basis..I continue to say they're "equal" for all intents and purposes.
Wil
philippeF 12-22-2005 11:58 AM
to follow :
may you tell me a good setup for my upcomming project
72' 2.4S with 2.7RS engine
front 7*15 with 195/65 tires
rear 8*15 with 215/60 tires
both road and track
thanks !
Philippe
Craig 930 RS 12-22-2005 01:28 PM
Wil -
You are correct. I took it a step futher and gave an un-aksed-for recommendation -
Wil Ferch 12-22-2005 01:51 PM
Craig:
That's perfectly OK.... maybe people ( newer people) here may not understand your decisive track bias..... :) :) :)
Wil
Craig 930 RS 12-22-2005 02:15 PM
Amen.
And until Bob pipes up with the answers to some questions, we won't know his mission. Track... street.....which tires?
Dixie 12-22-2005 02:33 PM
There are some basic alignment tenets. Two are...
  • Always trade camber for caster.
  • More rear toe allows you to get on the throttle sooner. (Limited by the HP, or throttle, you have.)
Therefore, "alignment two" is more aggressive.
But it's only nominally more aggressive. So little, I don't think it's of consequence other than supplying a touch more tire life at the track. Personally, I'd try to get -2 degrees camber, with a bit more in the rear, and keep the rear toe-in at .10. I'd also set the front to at least zero toe, and use toe-out for short track, and auto-x use.
RSBob 12-22-2005 09:08 PM
What I am primarily shooting for is probably what a lotl of us want, an agressive set-up for the street (read: the twisties) with some limited track time. Actually a car for each pursuit would be ideal.
Set up 2 had Dunlop Sport D40s
Set up 1 has SO3s
As background - Setup 2 also had Recaro SRDs. Very grippy seats. (All corduroy)
Set up 1 now has early RS Style replicas - Nurburgring from GTS (leather with cord inserts).
This is the situation: With the SRDs, the Dunlops, and setup 2, the car felt much more planted - but I am betting it was the seats really holding me 'in'.
The Nurburgrings, the SO3s (1000 miles), and Set up 1 make me feel much more tenuous in the corners.
It may be a combination of factors, or just the seats.
Any ideas since the suspension set-ups are so close?
And the pic, as requested:
http://forums.pelicanparts.com/uploa...1135317683.jpg http://forums.pelicanparts.com/uploa...1135317721.jpg
Jim Richards 12-23-2005 03:40 AM
Rick, I also have the Nurburgring seats from GTS, but I use Toyo RA-1's on the track. Probably more sticky than the tires you use. I have to chinch my shoulder straps down quite snugly to keep my body for moving around too much while cornering. I feel fairly well planted, but I know that real racing seats will make me more confident in the turns. It looks like you're using 7's front and back. What tire sizes? I run 6's and 7's, with 205/50/15 and 225/45/15 tires. I'll try to remember to look at my alignment specs tonight and post if they're much different than yours.
