Fuel pump replacement?
I have a 1974 911 CIS 2.7. Is there a possibility of replacing the fuel pump with a new improved aftermarket fuel pump. What are the spec's I should look for if this is possible.
Chris
Signature Phrase " CATCH ME IF YOU CAN"
1988 Porsche 930 "Squerly" Built by "Porsche Doc"
1974 Porsche 911 (2003 - 2012)
2000 Boxster S (2006 - 2008)
Old 12-20-2005, 07:33 AM
bigchillcar's Avatar
chris,
what is the justification for the need for a different pump? a working original should be satisfactory if you're staying with the stock cis motor otherwise..
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 12-20-2005, 08:39 AM
I dont know. Just thinking with my hands. I thought new technology in the car would improve reliability, performance and peace of mind.
Am I wrong in my thinking.
Old 12-21-2005, 06:51 PM
Nitrometano's Avatar
The only important thing about the fuel pump is the capacity to flow gallons per hour (gph) and the constant pressure or the pressure that can make for the specific engine needs. Most of the fuel pumps have up to 20% more capacity for fuel supply than the engine needs.
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 12-21-2005, 07:05 PM
Grady Clay's Avatar
Chris,
The best thing you can do is to relocate the pump from the
rear to the front cross member like the ’69-70 and the ’76
and later. Of course a new fuel pump (OEM or later) never
hurts but is only necessary when close to failure and/or noisy.
Here is the ’76 installation.
© Dr. Ing. h.c. F. Porsche A.G.
Best,
Grady
Old 12-21-2005, 07:25 PM
The Bosch CIS fuel pump is a mechanically great unit imo. I still use it.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-21-2005, 07:26 PM
There are good aftermarket electric fuel pumps that can be installed in place of the Bosch pumps. They are slightly smaller and lighter that the OEM units and generally can be had with the correct pressure/flow rate specifications (there is one that is a perfect match for a 1974 CIS system). The vendors typically have a selection of fuel connection fittings that allow them to be readily installed in 911's in place of the Bosch units. The only apparent advantage other than the slight reduction in size and weight is that they are about 1/3 to 1/2 the cost of the Porsche Bosch units. If your present OEM unit is working correctly I'd leave it alone as you won't gain much by changing it as long as it is putting fuel out per it's design specifications. That being said low fuel pump pressure and flow rate will reduce power output in a CIS car. I'm still running around with my 29-year old OEM unit but I also carry one of the aftermarket fuel pumps as a spare.
Old 12-21-2005, 08:05 PM
Fidalgo911S's Avatar
Jim, do you have the name of the aftermarket pump? I've still got the original in my '74 S and I'm just waiting for the day it gives up the ghost. I wouldn't mind saving a few bucks by not having to purchase the Bosch unit when that happens.
Old 12-21-2005, 08:12 PM
Walbro, model: GSL392
Old 12-21-2005, 08:18 PM
Old 12-21-2005, 08:22 PM
Retired Member
Charlie V's Avatar
Pelican sells a ton of good stuff.
I replaced my pump with the a Bosch pump that I picked up at a local euro car parts supplier. This one was for a late 70's VW Rabbit. This is the best part.....50% of the cost of the Prosche part and it is the same damn pump - exact same Bosch part number.
With the extra $ I purchased more things from Pelican.
1982 911 SC Targa - Rosie....my Mistress. Rosewood Metallic on Dark Brown and Black. Long distance road warrior and canyon carver. A few mods - a little interior, some brakes, most suspension and all of the engine.
Old 12-21-2005, 08:31 PM
Thanks Jim.
Old 12-21-2005, 09:01 PM
