Southern Class & Sass
Dixie's Avatar
Question Replacing "upper velvet seals"
Has anyone replaced the "upper velvet door seals"? What's involved in replacing these? Can you do it without taking the glass out?
Today I popped off the outer aluminum trim (no. 11) and replaced the squeegee seals (no. 9). In the process, I discovered the velvet seals (no. 7) underneath are beyond tattered. While replacing the squeegees was the easiest repair I have ever done, I suspect replacing the velvet seals is more involved...
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 12-26-2005, 11:20 AM
Dixie's Avatar
Anyone
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 12-26-2005, 12:34 PM
they have a series of tits that pop into holes in the door. slip a putty knife or some other flat tool between the felt strip and door metal and up next to a tit and twist. installation is obvious, but some of the tits typically resist going into the holes.
206 637 4071
Old 12-26-2005, 01:11 PM
Dixie's Avatar
Thanks John,
I take it there is no need to remove the glass?
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 12-26-2005, 01:33 PM
No, you can do it without taking out the glass, I did it a few months ago.
It can be really frustrating though.
One tool that I found really handy was a really thin flat set of wire strippers I had. I could get the end in there with them and position it side to side since I had a grip. After that pop them in with the putty knife or something else nice and flat.
Rob
1980 SC - 2011 Tiguan - 2018 Tesla M3P
Old 12-26-2005, 02:04 PM
