I've been using the Westco Miata battery for the past three years, but I haven't kept it charged up so it's prematurely weakening.
The one problem I have with it is that it's so tall that the positive teminal is wedged next to sheetmetal, protected just by the plastic boot. The dimensions are 7.5"Lx5"Wx7"H. Here's a pic (it's spaced out with foam, and could fit in much deeper): ![]() So I'm thinking about replacing it with a shorter, wider battery like the Odyssey 925T which is 6.5"Lx6.75"Wx5.5"H. http://www.odysseybatteries.com/battery/pc925t.htm Has anyone fit this battery in an early car battery box? |
I would rather be driving
I have one in the driver's side. (single batt and the pass side box removed for oil cooler). Works great. I had to fab my own tie downs for it. I have it on the side with the posts facing toward the center of the car. I have gone 6 weeks without starting it and it cranks over every time.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
