-   -   Name the washer/Victor Reinz part (http://forums.pelicanparts.com/porsche-911-technical-forum/258100-name-washer-victor-reinz-part.html)
JohnJL 12-27-2005 11:56 PM
I dis-assembled a motor and am re-assembling/rebuilding now. Unfortunately the Victor Reinz gasket/rebuild kist don't come with any part list(?!?!)
Here's a pic, can anyone help with these? I am guessing C is a valve bushing, but I had the heads done by a local shop so no wonder I don't see those...
Any of the others look familiar? I am following Wayne's book....
http://forums.pelicanparts.com/uploa...1135756551.jpg
thanks all
Rot 911 12-28-2005 06:34 AM
Those are the useless extra parts that don't fit anything. For example "G" is an exhaust gasket that doesn't fit any 911. Except maybe a turbo, but not even sure about that.
Jeff Jagusch 12-28-2005 06:40 AM
Item C
HI,
That is an exhaust gasket like Kurt said,
It is made from flexible graphite and wire mesh.
It is probably the best high temperature gasket material available.
It's physical properties are unchanged at temperatures up to 1200 F.
Jeff
JohnJL 12-28-2005 01:06 PM
Thanks guys...how about B and F?
Vin-barrett 12-28-2005 01:22 PM
item B
B is a CIS injector seal
ChrisBennet 12-28-2005 01:25 PM
"B" is a CIS injector O-ring.
"C" you guessed right, that is a valve shaft seal
"D" looks like distributor O-ring. (I never replace these, never seen one leak and a new one makes is a b**ch to get the distributor in.)
-Chris
Jeff Alton 12-28-2005 03:01 PM
G fits a 964 exhuast. I have a whole collection of those things! I am not sure why they end up in every darn gasket set I buy!
Cheers
HFR_Racer 12-28-2005 05:02 PM
Is F an oil drain plug crush washer?
bigel 07-09-2015 02:59 AM
Trying to resurrect this old tired thread because I am now in the business (not actually) of sorting out the many Victor Reinz seals, o-rings and gaskets that came with recently purchased rebuild kits. I have emailed VR in Germany as well as their US representative, but have not heard a peep.
I purchased the complete engine and head gasket sets, which came in several sealed, numbered packs. Some parts are quite obvious as to their purpose and placement on the engine, but others are very close in size/shape and I can't figure them out.
Any assistance or guidance on how to get a cross reference or listing would be much appreciated.
As a first-time engine rebuilder, I'm feeling a bit over whelmed right about now...
cabmandone 07-09-2015 05:48 AM
Only thing I can recommend is as you disassemble and come across a o ring or seal, match it to one in your kit then mark the location.
Flat6pac 07-09-2015 09:15 AM
I got 35 years of leftovers, if you wanted to sort things...
G fits the 2 piece cross over pipe, mid 70s through some early SCs
Bruce
boyt911sc 07-09-2015 11:16 AM
Extra parts from the package........
Steve,
There are so many extra parts in the set that you won't be needing for your rebuild project. What is important is that you have the parts needed for your rebuild. Like Bruce A. said, you will accumulate over the years the extra o-rings, washers, seals, etc. Save them because they come handy sometimes. After a dozen engine rebuilds, I have now a small zip lock bag of these unknown parts. Keep them in small baby food jar to remind you of your first engine rebuild.
Tony
