Master Cylinder Electrical Connection
Changing my 20mm M/C to a 23mm. The electrical connection farthest to the rear on the new M/C has a three prong connector and the old one had a two prong. Any suggestions?
TIA, John
1985.5 944 GTS |
Is it the reverse switch? If so can you just swap the two prong one for the three prong one?
I can't swap the connectors as I've sold the existing M/C to a Pelican and don't want to stick him with the same problem.
John
1985.5 944 GTS |
What's Facebook?
You can order a 2 prong switch from Pelican or modify the plug to allow the third prong to clear. The switches are for the brake lights.
Turborat "’Cause every once in while, the lion has to show the jackals who he is” 1979 911 SC - 2100 LB track rat 1986.5 928 5-Speed - 36,000 miles 2001 330Ci |
I had the same thing-ended up making jumper cables from the 3 prong female plug with spade connectors onto two of the MC switch connectors. That way I kept the stock plug on. The brake lights work fine. Simple crimp-on spade connectors sized appropriately....
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
You can use just one switch if you want. I only use one on my twin MC setup and the lights work fine.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Finally getting around to these connections. There are two leads in the wiring harness. The wires are the same on both connectors with a black with yellow tracer on one side and a blue with green tracer on the other. Does it matter which connector goes to which side of the plug on the M/C?
John
1985.5 944 GTS |
