aluminum bezel adhesive
What adhesive should be used to attach aluminum bezel rings. Mine did not come with it. I would like to be able to remove if necessary without damage so need appropriate adhesive.
Old 12-28-2005, 08:51 AM
Just pick up some double sided tape and cut small pieces--two per bezel. This will hold fine and allow you to remove easily. Double sided tape is what comes with them.
1980 911SC Targa 3.6L
Old 12-28-2005, 04:02 PM
84porsche's Avatar
Send a message via Yahoo to 84porsche
I used a poster adhesive (blue stuff) from a hardware store. I preferred this to double sided tape.
Modes of Transportation:
1984 Porsche 911 Targa
2003 VW Jetta GLI
Old 12-28-2005, 04:12 PM
Recreational User
DarrylD's Avatar
I used 3M strip caulk, 3 small "pea-sized" balls per ring. Stays on great but comes off easy when you want to clean the lenses.
Old 12-28-2005, 04:41 PM
Thanks I ordered them from ebay and well not exactly what I expected. They do not go over entire gauge ring. Instead they fit, perfectly, inside the gauges. Still gives very nice look of aluminum but must adhere from outside edge of ring to gauges. still for $74 shipped from Germany not too bad. Thanks for the replies. I was reading that appropriate adhesive comes with rings which fit over entire gauges. I was wondering what that was.
Old 12-29-2005, 12:34 PM
