Early Heat Exchanger QUIZ
Why do you never see any of the original heat exchangers from the earliest cars around.
scroll down for answer Answer: It turns out that these heat exchangers had a seam for the exhaust tubing inside the clamshell, which rusted in use and was a potential source of carbon monoxide poisoning. These heat exchangers were the subject of a comprehensive recall by Porsche, which replaced them all with the "S" type from 1967 on. This was cited in one volume of Up-Fixen, I don't recall which, but will post the volume and page number next time I run across it.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Cool stuff John . I never knew that , nor have I even seen that type . Very cool indeed !
Kurt Williams
Never drive faster than your gaurdian angel can fly. 82 SC w/965S eng and G50 6:1 hp/w ratio 72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles 65/66 912 1 owner 76k orig 01' Aston Martin DB7 V12 Vantage Coupe 6spd |
GAFB
Finding a set of those would be the ultimate score for a 'showroom' clean concours '65. I bet they all went in the steel recycling heap though...
Several BMWs |
