fuchs engine oil
Recently my car was serviced at a different workshop, and the oil used was fuchs engine oil compared to castrol whichw as in previously.
Then today my friend who is a mechanic saw the Fuchs hi-tech lubricants sticker on my windscreen and started telling me how bad the oil is compared to Castrol and how their trucks have ran poorly on this oil etc. Now I'm concerned my car has a sub-standard oil in it. Please can anyone tell me whether this oil is OK or not. Also, the car is a 3.2 Carrera. Should I be using mineral oil or synthetic? Cheers RG5 |
fuchs makes very high quality oil.... descriptions there of the various weights and some race/street oils....i would sleep easy!
brant giere 2005 996 cup 1991 964 euro cup (Larbre #28- race 1987 carrera 3.2-street/de car 1962 Austin Healey 3000 |
Don't worry about it. The differences in today's motor oils are so small that it is nothing to worry about. There may be superior products for your car, but there is no need to worry that what you have in there will do any harm.
I am a believer in synthetics for Carreras but how much additional benefit you might realize over conventional oils really depends on your application. Don
72T Coupe - SOLD :-( |
Diss Member
Re: fuchs engine oil
If you operate the car in temperatures lower that -10 degrees you can see a noticable difference in the way the car warms up if you use a true synthetic. If you look at long term wear (especially if the engine is seeing high temps) you will see differences. You might see differences in levels of deposits. The fact is differences in oil are mostly paying for ultimate longevity and insurance to make sure nothing goes wrong. BTW - Castrol doesn't have the best reputation. If you are going to pay the extra money for synthetic there are much better oils out there.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Thanks guys. According to my mate, he reckoned that the Fuchs was much thinner than the Castrol for the same grade, and that the trucks made a burning smell when running on the oil - as though the temp of the engine was actually burning the oil inside the engine.
Also, he said that the trucks consumed several litres of oil compared to runnning on Castrol, and that also some trannys had failed running on the Fuchs. He even went on to say that a local business which makes transmissions almost went bust running on Fuchs oil as so many transmissions had failed allegengly due to the Fuchs oil! Given this voiciferous derision of the Fuchs I thought it best to ask the question before demanding my mechanic to empty the olive oil out of my car and putting something decent in. Sounds like my mechanic is exaggerating a little from your responses! Rg5. |
I would be afraid to go to a mechanic who cannot read the specs on the containers of the various kinds of oils to use for the different types of engines and trannys out there. The manufacturer usually specifies what lubricants to use (in case of motor oils the type regular or synthetic, viscousity range 0,10, 15W-30,40,50 etc, SAE rating up to J now, in case of gear oil GL-# 5 for 915 gearbox). Just follow the owner's manual rec from Porsche and all will be well.
Crotchety Old Bastard
With a name like Fuchs it has to be dam good jam.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
They sponsor racing efforts as well http://www.fuchs-oil.com/motorsport0.html
Warren & Ron, may you rest in Peace. |
