New Undercoating Removal Tool
I just got this in the mail today from Auto Body Toolmart - http://www.autotoolmart.com/cgi-bin/webc.cgi/st_prod.html?p_prodid=9798&p_catid=144 It's only $210 compared to the Wurth equivalent for around $450.
I recently saw the Wurth tool in action and was impressed but couldn't justify the price difference seeing that the tools look almost the same - the wire wheel looks exactly the same, probably is.
I reccomend one to anyone thinking of removing their undercoating.
Craig Backer
Old 01-04-2006, 01:14 PM
Couldn't you fit a replacement wire wheel on a $19 pnuematic die grinder or cutoff tool?
Warren & Ron, may you rest in Peace.
Old 01-04-2006, 01:18 PM
FrayAdjacent911's Avatar
Send a message via AIM to FrayAdjacent911
I'm glad my undercoating is apparently just chipping off... when I get to getting it all off, it might just take a putty knife!
Matt J.
69 911T Targa - "Stinky"
2001 Boxster "Stahlgewehr"
Old 01-04-2006, 01:20 PM
They make it so it only works with their tool.
Old 01-04-2006, 01:33 PM
Interesting tool. Good luck with it.
Here's a product from Eastwood that is interesting as well.
"Under Gone Undercoating Remover Aerosol 16 oz
Undercoat removal made easy! Here's the solution for undercoats that can be imprinted with a thumbnail. Biodegradable undercoat remover quickly loosens the bond of the undercoating to the base metal and allows you to easily scrape it loose. Use PRE Painting Prep to remove any remaining residue for a "paint ready" surface. Not for use on baked-on, epoxy or urethane undercoatings. For cleaning up an area to be welded, this is a must! 17 oz. net wt. aerosol. $10.99"
Old 01-04-2006, 01:46 PM
rob justice's Avatar
I used a £10 heat gun - did the whole underside in less than a day - smelly though.
Old 01-04-2006, 01:57 PM
Navin Johnson
TimT's Avatar
The UnderGone Undercoating remover didnt do squat to the undercoating on my 911 Save your money.
I used a heat gun, putty knife, and knotted wire wheel.
'69 911 GT-5
'75 914 GT-3
and others
Old 01-04-2006, 02:00 PM
makaio's Avatar
Couldn't you fit a replacement wire wheel on a $19 pneumatic die grinder or cutoff tool?
You could, but it's not recommended for most of the cheap wire wheels and cups you see. Most of them have a much lower rpm limit than most die grinders will do. To much rpm, and they start to disintegrate, and shoot the wires out.
Old 01-04-2006, 02:12 PM
B D B D is offline
B D's Avatar
That tool or ones similar work great but make a real mess. The job with the tool is so simple but messy I know of shops that use day laborers for this type of work. Make sure to wear a mask and goggles.
68 911L
Old 01-04-2006, 02:25 PM
undercoating
you just need to get in there and get dirty.. heat gun, propane torch etc... the knotted wire wheel is the bomb but man does it make a mess.. heat gets it stinky and the wheel will have little wires and junk EVERYWHERE... keep us posted..
David Brunson
Sharpsburg, Ga
1966 #300720 sold
Old 01-04-2006, 03:25 PM
randywebb's Avatar
Then there's the dry ice method...
When I do this on the interior side of the R firewall, I'm gonna try out my Fein Multimaster tool (looks like a triangular/corner sander).
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 01-04-2006, 06:02 PM
i own the wurth tool. i think i paid 200 bucks for mine a few years ago. i am interested to see how long the brushes last. keep us posted. eyeware safety in a must. it is simply the best tool for restoration i have ever owned. rust, paint, undercoating, tight spots, absolutely no problem. i have used mine countless hours, and loaned it out so many times...i would highly recommend the wurth tool, even if it is expensive. you tend to get what you pay for.
Old 01-04-2006, 06:45 PM
I like the fact that you can resharpen the bristles by running in reverse against a grindstone.
The traditional wire wheel method is a die grinder (or 4 1/2" grinder) with a $10 wire twist wheel.
Old 01-04-2006, 07:49 PM
Zeke's Avatar
"The traditional wire wheel method is a die grinder (or 4 1/2" grinder) with a $10 wire twist wheel."
That's what I use...on a 7" angle grinder. Stand back!
Old 01-04-2006, 09:11 PM
