1981 911SC Alarm Control Unit Part #
Anyone know what the correct part # is for the factory anti-theft control unit module (that is in luggage compartment I believe)?
Car is US-spec 1981 911SC with door jamb alarm key switch. Pelican lists several with 911-637-104.xx part #s Not sure if any of those are correct for 911SC and would check myself but car is away in storage for the winter Thanks in advance! |
PET shows 911 637 104 00 for your car.
JR |
Man, this is like real time! Many Thanks!
schoward,
Here is a thread you may want to read and print out for future reference: http://forums.pelicanparts.com/showthread.php?s=&threadid=59329&highlight=wont+ru n If your factory alarm is inoperative or acting up ... there is a 'bypass procedure' you should know about and be prepared to do. Otherwise, your car may be inoperative when/if the factory alarm unit fails! |
Early s man - just what i needed. thanks.
I will attempt to resurrect the alarm this spring and am assuming the worst (which is that I will likely disturb some old patchwork fix/disablement) and need all the info i can get |
| All times are GMT -8. The time now is 07:29 PM. |
