Motronic 3.2:idling high
Idling high , is it time to clean mass airflow/ t/b. When would I be required to do that service?
It is idling high at over 2k. Maybe the microswitch went out. I can hold the throttle down with my hand firmly against the microswitch and it lowers idle if I recall. It was last week. I started it today and it is idling high. The first time I cranked it, it idled properly. Pull out of the garage and idling high. Would like to lower the idle. First, will pull off the K & N Airfilter and purchase cleaner tomorrow. What would you do next? Thank You. Regards,
Bernard Last edited by BReyes; 11-18-2005 at 06:40 PM.. |
How old is the O2 sensor? It sounds like it's not getting signaled to go out of cold start.
I'm not aware of a procedure to clean the MAF barn door / TB. It's easy enough to remove and inspect however. Be very careful with the barn door in the MAF, the rheostat is dicey and does wear out. You can get a rebuilt MAF if that's the case. Don
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
Don:
SSI. Backdated. PO put in a chip? Recent TE rbld. Stainles steel fuel lines. Idle control valve has 10k miles. It revs past 7200 rpm. Highway driving recently, now it idles high.
Bernard |
GFCC
Check your Idle Position Switch (IPS). It is located on the driver's side of the throttle body. Its plug is on the opposite side. To test it, Check continuity between the two posts on the plug. There should be continuity in all positions Except fully closed. If this is not the case; on the side of the throttle body that has the sensor there is a screw just in back of (towards the back of the car) and below the IPS that adjusts that setting.
Jeff 1976 911 Coupe w/ Euro 3.0 - Sold 1987 Carrera Coupe - Sold 1999 Carrera Cabriolet - Current |
MBruns for President
Check your return spring and throttle cable for adjustment too (drivers side, transmission)
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
make sure the cruise control cable isn't hanging it up. You can pull the cable out thru the slot by the throttle body and loosen the plastic adjuster
Jeremy: Put my arm down by the tranny (car on the ground) and pulled a little and voila. Down the road, and what do you know it did it again, but controllable with a blip. Blip.
Bernard |
Bernard - there is an adjustment screw there - Thought I had a picture of it but don;t.
Had the valves adjusted by Frank Eibell and he greased it. Alot less blip is a good thing. It comes down easy at slow down off a pass on the gandy.
Bernard |
Frank knows how to put in lube in the right places
![]() Burned another set of Pirelli's...
Bernard |
Bellcrank (on the trans) bushings were gummed up - yes?
anh911 '94 Dakota - Meh '98 Moto Guzzi - woo hoo 911; XJS; Islander 36; All Sold '97 YZF1000RJ - Totaled (Not by me) |
I would replace the K&N system with the stock OEM dry paper filters. The oil from an over lubed KN will gum up the trap door of the AF sensor in time and cause poor idling issues Also unless there are other proper mods your engine will not benefit in any way from the K&N filter.
Anh911 Yes I guess it was dry. Now lil lube
![]() tshih: Yes the 3.2 has the proper mods and she is driven hard, and built to do nothing but. And the chip can really let her unwind. Have never run a tank of anything but preium 93 octane. The K&N is always cleaned out and no problems.
Bernard |
