Where does this bracket go?
Can anyone tell me where this bracket belongs?http://forums.pelicanparts.com/uploa...1136244625.jpg
It goes from a bolt that holds the chain box to the engine case up to the AC bracket. I think........
Cheers |
Looks like it mounts to the AC bracket. Maybe someone can post a pic of how it fits.
A.C. bracket it is. Thanks all.
Pat |
A special "stepped" nut is required to mount it to the chain box stud (if you are going to mount it).
Yep, just removed this this afternoon, it is a tight fit in behind the oil pressure sender, as Jim notes it uses a strange little stepped nut to attach to the stud
| All times are GMT -8. The time now is 04:23 AM. |
