Banned
gassy's Avatar
Send a message via ICQ to gassy Send a message via AIM to gassy Send a message via Yahoo to gassy Send a message via Skype™ to gassy
Do I need a new alternator?
The car is dead after 24 hrs. Jump it, same thing. Batteries register full charge.
Thanks in advance
Old 01-02-2006, 12:09 PM
Banned
gassy's Avatar
what does that involve? learning as I go.
Old 01-02-2006, 12:12 PM
David's Avatar
Put a volt meter across the battery terminals with the engine off it should be about 12.3 to 12.7 with the engine running it should be about 13.7 to 14.5. (those are rough numbers)
Old 01-02-2006, 12:19 PM
Banned
gassy's Avatar
thanks man
Old 01-02-2006, 12:25 PM
Banned
gassy's Avatar
I was just reading one of the links you posted--the batteries are older than 5 years--i'll start there...thanks again!
Old 01-02-2006, 12:34 PM
Or...your battery charging light is burned out..and it doesn't just mean your light is gone , it means the excitation voltage is not there and could cause electrical problems.
Do this, turn the key to "on"...but not so far to "start"..is the battery light on ??
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 01-02-2006, 12:42 PM
Banned
gassy's Avatar
Thanks Wil--my car is in storage at work--otherwise I'd try it right now--I'll try that this week. Thanks,
Christian.
Old 01-02-2006, 12:56 PM
ThePointman's Avatar
Send a message via ICQ to ThePointman
I just had my alternator rebuilt and what has been mentioned above is exactly what you need to do. Put a voltmeter across the battery terminals when the engine is running. It Should read from 13.7 to 14.2 volts. If the reading is less then 12 volts you have a charging issue which would most likely be the alternator. Once removed the alternator can easily be tested.
Old 01-02-2006, 01:58 PM
Where to have the alternator tested?
I'm helping a friend disgnose a charging issue and would like to have the alternator bench tested. The local Kragen said their computer didn't recognize the Porsche alternator and thus they could not test.
Does this need to go to a specialty shop?
Thanks,
Mark
'88 Carrera GPW Sunroof Coupe
'82 SC Targa (RIP)
Old 01-04-2006, 10:09 AM
